Page 1 of 2 12 LastLast
Results 1 to 20 of 29
    i got a 2nd hand honda, nag overheat cya wen i drove it to bulakan. My First time to drive kaya nlagyan ko agad ng water un radiator n patay un makina. after that incident. hinde n ok performance ng car. pnatganan ko s mechanik. tngal nya un thrmostat coz tumataas pa din temp. advise nya is top overhaul. nde n daw pantay un cylinder head kaya my singaw n s makina.until now hinde ko p napapaayos. pag pina top overhaul ko n kaya un,mawawala n un overheating? any suggestion? bulakan po ang location ko ngayon.
    pati radiator pa overhaul na rin... or palit na lang ng surplus.
    Hello there.
    Binuhusan mo ung radiator ng tubig tama ba? Some say baka lalong makasira un ng rad since nagoverheat ka nga and binuhusan mo ng tubig. You know, the reaction of hot metal when mixed with water.
    Anyway, if ever cylinder head mo nga may problema and mapagawa mo sya, kelangan patingin mo na din ibang cooling system components mo to be sure. Actually, yung cyliner head replacement na pinakamahal among all components. Here are other parts that you should check.
    1. radiator
    2. aux fans
    3. thermo switch
    4. thermostat
    5. water pump
    Oto ko kase LX naman and I had overheating problems before. Checked all those 5 components and so far ok na sya. Hope this helps.
    Thank u mga Sir for your comments....
    i had already check the radiator, n p overhaul ko n..but still mataas p din temperature nya, especially pag akyatin un daan.
    thermostat was been remove temporarily, dapat mapalitan din kasi pansin ko nun tinanggal thermostat,naging wet n un usok s muffler. and lumakas n s gaso....
    Thermo switch ok p din kasi automatic p din un auxilary fan ko...db un ang trigger for the fan to rotate.
    water pump, still have to check it. san kaya located un s engine? near the inlet hose,where the thermostat located.
    any suggestion po kaya n reliable shop to fix my car? within manila or bulacan....para lapit lng place ko.
    im planning to fix it up this coming vacation.
    tnx a lot.....
    Yung water pump nasa bandang timing belt.
    May tubig coming from your muffler? May sira na nga ata cylinder head mo. Ibig sabihin kase nyan pumapasok na tubig sa engine mo. I don't think the thermostat has got something to do with that.
    As for your radiator, minsan kase kahit na-overhaul na sablay pa rin. Depende din kase minsan sa nag-overhaul. It would be better kung bili ka na lang bnew radiator like Evercool. Mura lang naman sya.
    Wala ako alam sa Bulacan or Manila. Maybe you can try Speedyfix sa Santolan. Highly recommended.
    What's with the smiley in your post?
    Anyway, sometimes the fan(s) fail(s) to turn on time, which causes overheating especially when the aircon is on. Try leaving your aircon on and observe if the fan turns consistently.
    Cylinder head problem? I guess that shop is just fooling around with you. Some d*ckhead mechanics find more problems in your car so that you end up spending more. Worse, your overheating problem is not over. The real problem area is probably the last one that shop will fix. Better take your car elsewhere.
    Aug 2003
    kung basa yung exhaust, at the very least siguro busted na yung cylinder head gasket.
    i assume nauubusan siya ng tubig very quickly?
    if you leave the engine on, with the radiator cap removed, tapos dagdagan mo ng tubig, yung tubig dun sa radiator, does it splash all over the place na patalsik?
    Oct 2005
    makikidagdag lang po...yung pagbuhos ng tubig sa radiator kapag mainit ay hindi recommended...kasi talagang masisira ang radiator. kapag tumataas ang temp, pull over, let the car cool for several minutes, and then open the hood. kuha ka ng basang basahan, ipatong sa radiator cap. allow the radiator cap to cool. kung nahahawakan mo na, tanggalin mo ang radiator cap, fill the rad with clean water, turn on engine, let someone rev the accelerator smoothly while you put water in the radiator. may hangin kasi sa loob ang radiator. pansinin mo kapag nag rev bumababa ang level ng tubig. magkukulang ang tubig kung lalagyan mo ang sasakyan habang patay ito. don't forget to fill the reservoir also upto the max level (wag punuin).
    May 2005
    The usual problem with EG Civic radiators is the upper portion (fiber glass) tends to crack and eventually leak. Either have the upper portion fixed or replace it with a surplus radiator for Php 5K or less. Btw, water that goes in the radiator needs to be mixed with engine coolant. Plain water in the radiator is a big no-no.
    Oct 2005
    Quote Originally Posted by number001
    The hell with those plastic radiator tops. We had ours replaced with a metal one since the leak can no longer be repaired. At least so far, no problems yet.
    Oct 2005
    IMHO those parts aren't designed to last the owner's lifetime.
    Nov 2003
    if you're going to replace the radiator. at least get a brand new evercool.
    next, if the head is out then you might as well get an overhauling kit. replace the valveseals and all the oil seals narin sabay sa gasket. best to also have the head checked for warpage and cracks. para isang gawaan nalang and sure ka ok na pagbalik mo.
    sirs,
    Thank you s info..its a big help to me...
    patgnan ko n din top engine..may leak n kasi un s head nya...and pa tgnan ko n din for warpage and cracks...
    any suggestion po s store n mura and orig for parts and kits....?
    auxilay fan is in operation naman...
    un water s radiator is sometimes..parang hinde circulate..pero nde naman natututyuan..
    Temp. nya is range: 50 % to 75% of the guage..mataas un d b?
    Quote Originally Posted by entoy
    sirs,
    Mataas nga yan. Usually kase it's just below 50%. Ninenerbyos na ko dati nung lumagpas lang ng 50% hehe.
    Sep 2005
    after ma top overhaul mo, di pa rin guaranteed na ok na yan. kaya siguro nag warp yung head bec nag overheat na sya. possibleng effect sya ng overheat not the cause.
    baka nga barado na yung radiator kaya di nagcirculate yung water. maski malakas fan mo, tataas pa rin temp nyan. replace na lang kung may budget. overhaul lang kung mejo tipid.
    Sep 2005
    oops, double post ako
    Nov 2003
    when the engine is cold, open the hood, open the rad cap and start the engine. may bulwak ba?
    What if d napansin na nagoverheat and continue parin andar? Auto shutoff be engine? (auto shut off kc sira na. wag yun, hehehe). Meron bang work around kung walang systema na ganun? Parang yund DIY intrument/light buzzer for EG. hehe.
    Quote Originally Posted by ineedmorehp
    yes, it is possible to build a simple circuit as an over-temperature alarm
    the sensor is a negative-coefficient thermistor so a simple comparator circuit using LM311 with few other passive components and a tiny 12V buzzer will do the trick
    but auto-shutoff of engine, although possible and easy to incorporate to the circuit as well, is not recommended for safety reasons
overn heating Honda ESi ,95
