Results 11 to 20 of 89
December 5th, 2019 09:08 AM #11
- Feb 2017
- 28
- 54,205
December 5th, 2019 09:55 AM #13
- 54,205
December 5th, 2019 09:58 AM #14we did, once, in our old besta. it worked fine, naman. but i couldn't tell the difference between a brand new, un-clogged, un-rusted standard-for-model radiator, and a brand new, higher capacity radiator. i did feel more assured, because my new radiator was higher capacity.
don't worry about "overcooling" (if such exists at all). the thermostat will take care of that.Last edited by dr. d; December 5th, 2019 at 10:07 AM.
- May 2011
- 481
December 5th, 2019 10:21 AM #15Only the additional weight if it matters. The thermostat controls the target temperature and ghe coolant temperature will adjust the operating parametres.
As long as it fits the bracket.
December 5th, 2019 10:23 AM #16
Diba meron na mga replacement na Taiwan made? Pwede na yun or tanong ka mismo sa denso baka mura na lang yan.
December 5th, 2019 10:30 AM #17
- 54,205
December 5th, 2019 10:50 AM #18
December 5th, 2019 11:11 AM #19
We used to do that in all our Taxis (after the radiator was replaced by a "replacement")
Using a Non-factory spec radiator (normally made of copper) has only 2 pros, it's easier to repair AND during those hot summer days, spraying the radiator with water can help the A/C.
But based on experience with replacement radiators.
It's bigger - but the rows are actually smaller
It gets hotter, higher chances of the hood fading quicker
I would also recommend to remove the thermostat as I'm not sure how will local radiators hold up.
Only issues I noticed with removing the thermostat is that (1) it will take longer for the car to warm up, if you're driving short distances, it can be really annoying.
(2) when driving at high speeds out of town, the engine temp will be lower than usual, hence again not reaching the optimum temp of the engine.
December 5th, 2019 11:17 AM #20
In most of Da Pilipins, over-cooling an engine will never occur. Not even in the highlands, I would think.
To the TS, also please remember the fan/radiator shrouds which are integral to the design to maximize the airflow into the radiator. Baka po kasi tanggalin at hindi na ibalik.
Better to buy the similar-era clone starex 4x4 (not sure lang if local or imported but original lhd...
Mitsubishi Philippines
