Results 231 to 240 of 287
November 13th, 2018 06:13 AM #231
^bro try mo daw compression test. not really sure how it would help, pero nabasa ko lang hehehe
antay natin mga tips ng iba
- 54,290
November 13th, 2018 07:35 AM #232
- May 2011
- 481
November 13th, 2018 08:21 AM #233It can have perfect compression test result even if the coolant is leaking into the combustion chamber s.
The preferred test for this concern and is more conclusive is a cooling system pressure test.
November 13th, 2018 08:23 AM #234
if you're not overheating or not even getting high temp on your gauge that shouldn't be an immediate concern. Now, question is gaano kadami yung bumubulwak sa radiator? afaik, kung hindi naman masyadong madami or malakas ang pag bulwak normal naman may bubulwak dyan pero dapat konti lang lalo na kung sarado pa thermostat at the time of testing, paki correct na lang mga master...
- Nov 2009
- 3,509
November 13th, 2018 08:49 AM #235Bumubulwak on cold startup:
1. Thermostat valve was removed by siraniko
2. Thermostat valve is stuck open
- Oct 2015
- 5
November 14th, 2018 01:21 PM #236
Before the old radiator was replaced, check on 3 but not anymore. I'm just concerned when I was told it might be a cylinder head issue since bumulwak yung tubig but that only happens when the temp is extreme not when it is cold
November 14th, 2018 01:35 PM #237
- May 2011
- 481
November 14th, 2018 09:36 PM #238
- Jul 2018
- 38
November 29th, 2018 06:03 PM #239Hello po again. I'm having temperature issues po with my 03 Honda City Type Z. The temperature is getting high so I stopped at the nearest gas station to get water to cool down. There were some bystanders who helped me out to figure out what's wrong with the car. They are saying that the radiator was clogged.
Here's what I know so far:
-the fans are working fine
-I'm not losing coolant and water from the radiator
Sent from my LDN-LX2 using Tapatalk
- May 2011
- 481
November 29th, 2018 10:11 PM #240
Looks like its is due for release next year: https://www.youtube.com/watch?v=1mLrd78Deng Also...
2026 Mazda CX-5
