Page 14 of 15 FirstFirst ... 4101112131415 LastLast
Results 261 to 280 of 287
    #261
    ADR yung three letter word na radiator siguro. Evercool is good too. Used it on my 96 City before. Disadvantage is tanso siya so mas mabigat sa stock na plastic/aluminum.
    Same sentiments. Sa dami na ng brands ngayon mas gugustuhin ko pa na brand new. Siguro kapag sobrang nagtitipid tsaka lang tsaka ako magpaparepair.
    #262
    Evercool is local OEM for mitsu kaya may kamahalan. The taiwans are cheap and good quality, i just replaced one for hyundai and throw away the old nabulok dahil hindi nagpalit ng coolant.
    Kaya yun DIY minsna nagiging Destroy it Yourself..Hehe.
    Kaka kalikot yung pyesa na nabuksan at nagalaw dun nanganganak problema.
    Kaya minsan need talaga research gather experienced method to find the root cause than the elimination method of troubleshooting.
    Eto co-worker ko nag PMI DIY ng brake drum cleaning na hindi binacking ang adjuster, ayon pinwersa using eject slot na tornilyo kaya misaligned need nya palitan brake shoes.
    #263
    Naging Destroy it yourself. Hahaha
    Its all part of the learning process....
    #264
    ill checkout my work later, kung ok ba or hindi yun alum clips
    if ADR nga yun sa toyorama, ok na kaya yung ADR bro?
    sa weekend mag semi long drive ako, then check if may leak yun DIY ko. ngayon kasi naka distilled water muna, kaso di madetect sa distilled water dahil nag evaporate agad, nun pinalitan ko nalang ng coolant, tsaka ko nakita yun mga tulo from a very small leak.
    Jun 2005
    #265
    bro ok ba brand nikko? ano brands gamit nyo na replacement lang? orig is * 15-20k eh
    observe ko muna diy ko, if not palit nako bago hehehe
    Nikko is one of the go to brands for vios parts ng mga mechanics that specializes on the vios...
    Sent from my MI MAX 2 using Tapatalk
    #266
    Same level si ADR at Evercool. Parehong locally made. I suggest go for two rows para may extra cooling capacity ka. Naka dalawang track day din yun plus daily drive pa. Walang problemang binigay sakin.
    ^ i'm not sure but i think taiwanese made ang adr bro.
    i bought an evercool rad for my ek several years back to replace the original oem rad it came with and it performed very well. the price is worth the quality of the product.
    btw, iyong adr ba aluminum na? kasi iyong 2 row evercool na nabili ko dati gawa pa sa brass.
    #268
    thanks bro
    will call toyorama now and confirm if ADR nga [emoji4]
    #269
    thanks bro
    promax daw dating ADR and same packaging.
    #270
    I might be wrong about the origin of ADR. But im sure evercool is locally made.
    #271
    nag sms ako dun sa number sa evercool fb page
    wala pa reply hehehe
    bakit kaya yun 3 store na natanungan ko sa banawe wala sila nun
    Sep 2018
    #272
    Quote Originally Posted by batang_angas View Post
    Hello po again. I'm having temperature issues po with my 03 Honda City Type Z. The temperature is getting high so I stopped at the nearest gas station to get water to cool down. There were some bystanders who helped me out to figure out what's wrong with the car. They are saying that the radiator was clogged.
    Here's what I know so far:
    -the fans are working fine
    -I'm not losing coolant and water from the radiator
    Sent from my LDN-LX2 using Tapatalk
    Other possible reasons why your car is overheating would be electrical problem or damaged thermostat or water pump. However, I suggest that you should visit your trusted auto shop to have your car checked to prevent any further damage to your car. Hope this helps!
    #273
    installed new rad ..
    lesson learned, if you know youve been using coolant since day 1. wag ipa overhaul ... LOL
    lesson learnt is true bro. walang corrosion!
    #275
    Two rows? And don’t forget to “burp” the cooling system to release some air pockets that may have been trapped.
    Made of Aluminum o brass sya bro?
    #277
    alum parin bro and 2 rows nga sya.
    burped narin sya bros
    nanghinayang lang ako dun sa orig na rad since wala naman problema nung una, nagkaroon lang after ng overhaul
    #278
    keep it as spare. you might need it in 10 years. heh heh.
    or sell it. here.
    #279
    or sell it. here.
    planning to fix it talaga bro, then keep as spare or pamigay sa vios user na mangailangan or pwede rin benta; whichever comes first LOL
    Dec 2017
    #280
    This is unfortunate, when you fixed something that is not damaged and now is broken...
    This is good information for those who are new to cars, leave the radiator as it is if you are using coolant. Follow manufacturer's recommendation for its interval when to replace the fluid.
Radiator / Overheating Problem
