Page 26 of 29 FirstFirst ... 162223242526272829 LastLast
Results 251 to 260 of 287
    #251
    eto naman mga leak spots na nakita ko, kaya ko binaklas yun rad.
    eto naman vid nung malakas na leak, even * idle ..
    tiny leak 2 - YouTube
    #252
    When it comes to radiators, i seldom repair. I just replace the assembly. Taiwan replacement are cheap arnd 2.5-4k and they have 1 week warrantey.
    Jan 2008
    #253
    Agree.. i have a multicab van with rear engine. Its radiator is placed in front.. radiator was repaired due to leak but did not perform as expected..
    Replaced with a brand new one for 1.9k and voila.. the engine loves the new radiator..
    #254
    bro ok ba brand nikko? ano brands gamit nyo na replacement lang? orig is * 15-20k eh
    observe ko muna diy ko, if not palit nako bago hehehe
    #255
    if my radiator leaked a second time, shortly after it got fixed once, i would replace it already.
    i prefer all-metal radiator, over plastic.
    lalang.. old folks thinking.
    magkano ba bukang-bibig peerless ?
    #256
    sarap kasi iDIY bro, will try one more time tapos bili na talaga ako promise LOL
    btw mga bros any ideas san nakakabili ng radiator na evercool and how much?
    #257
    Not familiar with brands but i bet with the batman you could compare the best replacement taiwanese brand, try calling toyorama for the recommended replacement brands.
    That red RTV i don't trust using in pressurized cooling system, they tend to leak if you don't get the uniform torque/ tightness of the crimp tabs. Same as with oil-pans, not unless the surface is perforated with canal designed for sitting the RTV gasket.
    #258
    bro sorry, you mean they have different taiwan brands that i can choose from?
    nun tumawag kasi ako toyorama, they offered a 3 letter brand name ala DFS 2.4k sa cruiser sucat naman nikko brand 2.8k
    sa Was naman, 5k taiwan din daw.
    Apr 2009
    #259
    agree with this. Plastic rads are somehow "throw-away" once its service life is reached. It is BEST to replace it rather than repair it. converting an aluminum rad with a plastic tank to a brass top tank will only have galvanic reaction and corrosion in just a matter of time and will give you problems. again. in the most unpleasant time...
    but in retrospect, if you took care of your cooling system, your rads will last. have owned different cars over several years and noted that STILL, the BEST coolant is the OEM specific for each brand. and replace it as per manufacturer's recommendation. nothing else....
    #260
    Quote Originally Posted by LN106G View Post
    mali ko kasi, malinis naman since nag fake overheating problem ako eh pina overhaul ko agad.
    ayun malinis pa nga since toyota long life coolant naman gamit ko dito
    bali nagkaproblema lang simula nun pina linis. sana man lang bago tumira yun mga nag gagawa nito, nag test muna ano?
Radiator / Overheating Problem
