Results 241 to 250 of 287
- Jul 2018
- 38
November 29th, 2018 10:33 PM #241
- Jun 2005
- 3,774
December 2nd, 2018 12:31 AM #242Maybe its as simple as a faulty radiator cap.
A friend had this intermittent overheating issue on his innova. After a few visit to his suking shop that found no problem, i opened the radiator cap only to see that the spring rusted and fell to the radiator
Replaced it with a new cap. No more overheating
Sent from my MI MAX 2 using Tapatalk
- Jul 2018
- 38
December 2nd, 2018 12:48 AM #243
December 2nd, 2018 01:06 AM #244
- Jul 2018
- 38
December 2nd, 2018 01:24 AM #245Actually I did nothing sir. Which really bothers me. I'm not sure what caused it to rise to the point of almost overheating that's why I'm trying to observe the car if it would repeat the same thing again, but so far everything is back to normal. [emoji848] But I'll have my mechanic to have a look at it, may be its just a faulty radiator cap or a water pump problem. I'll let you know once I have figured it out.
Sent from my LDN-LX2 using Tapatalk
- 54,286
December 2nd, 2018 01:30 AM #246perhaps it is the fan.
it may be rotating, but it is not rotating as fast as it should.
if one drives long enough, the coolant will overheat.
i had problem with my sentra before. the fans were working, but when i compared the volume of air the old ones were pushing, to the amount of air new fans would push, i replaced my "still-working" fans. that solved my overheating problem.
another possibility is clogged radiator tubes.
but i finally got to the fans, after ruling out the other possibilities.
it was a tedious process spanning almost a year.Last edited by dr. d; December 2nd, 2018 at 01:44 AM.
December 2nd, 2018 08:55 AM #247
^ Doc Is there a sure way to determine the slow but progressive deterioration of the operational capacity of the rad fan?
I regularly check the coolant reservoir of my fd2's rad and i notice there's a gradual decrease in the amount of coolant in it in a time frame of over several months.
do what you gotta do so you can do what you wanna doLast edited by baludoy; December 2nd, 2018 at 08:58 AM.
- 54,286
December 2nd, 2018 09:05 AM #248
it's like growing kids, i suppose.
if you see them every day, you won't notice their increasing height.
but if you see them only once a year during mano-po-season, you will notice it, that is, if you remember how short (or tall) they were the previous year..
but if i were to hazard a guess... i probably would suspect it if my temp needle goes beyond what i normally see.
in my car, that would be beyond the halfway mark to, say, at least 5/8 , in heavy traffic.
my other car kasi (no aux fan, but a direct-drive with silicone-operated clutch), or my sentra when it was new, kahit one hour in standstill noonday traffic, the needle still kept a little under halfway.
in my instance, i thought the blow was strong. only a side-by-side comparison convinced me otherwise.
in retrospect, it was my over-reving temp needle (won't work with some cars' idiot temp warning light), and the loss of coolant, both in the radiator and in the reservoir.
the soundness of the old-timer's advice hit me, when i actually saw steam bubbling out of the reservoir. it meant that my coolant in the radiator wasn't getting cooled, and was bubbling out into the reservoir, resulting in overheated reservoir coolant, thus resulting in bubbling.
i expected similar symptoms with a clogged radiator. but as i know for a fact that my radiator had recently been cleaned...Last edited by dr. d; December 2nd, 2018 at 09:44 AM.
December 5th, 2018 01:43 PM #249
update lang ..
marunong nako magbaklas at kabit; plus minor repair ng radiator
naka 2 backjob na kasi ako dahil sa top leak, gilid ng dugtong. after kasi kabit ng rubber gasket, nilalagyan ng sealant (gasket maker), which is OK sana kung sakto pa yun rubber; so nilalagyan ng gasket maker. ginawa ko, tinanggal ko yun rubber gasket, then gasket maker nalang from pioneer. so far 3 hours na of driving (2 hours during sunny weather), wala pa leak.
ok lang sana kung distilled water lang gamit ko, kaso sayang mahal na ng coolant * 380php per 2 liters (IIRC)Last edited by ninjababez; December 5th, 2018 at 01:47 PM.
December 5th, 2018 01:48 PM #250
yun rubber rubber gasket kasi, binabalik nila tapos lagay ng gasket maker. kaya siguro nagkaka leak?
[img]https://uploads.tapatalk-cdn.com/20181205/da1302b2252b80620b10e73084351e66.jpg[/imx]
Clean and neat!
2023 Toyota Innova (3rd Gen)
