Page 2 of 15 FirstFirst 12345612 ... LastLast
Results 21 to 40 of 287
    Oct 2013
    #21
    Thanks mga sirs sa inputs nio. At least may idea na ko ng pwede cause ng overheating
    baka may kakilala kayong naghohome service na mekaniko. ayoko na sana ibyahe. Guadalupe, Makati Area
    Sent from my SM-J700F using Tsikot Forums mobile app
    Oct 2013
    #22
    Quote Originally Posted by mina_nuka View Post
    What was the last thing performed to the engine that might involve the cooling system?
    Ās per this diagram
    toyota avanza thermostat - Google Search
    The system should have been bled at two places if at any point the coolant was low or was drained and refilled
    Last thing na ginawa ko for cooling system is nagchange ako ng motor ng fan ng radiator last year
    May 2011
    #23
    Quote Originally Posted by misterioman View Post
    Before doing anything or having anything done to it, top off with antifreeze/coolant and bleed the system
    May 2013
    #24
    Kung nagbabawas ng tubig/coolant at walang leak, I would replace the radiator cap.
    #25
    Quote Originally Posted by andsmv View Post
    i have a nice collection of near-brand-new caps.
    but everytime, the problem turned out to be "something else".
    we live and learn.
    May 2011
    #26
    we live and learn.
    Been guessing eh😁
    Dec 2009
    #27
    What is your reference level for the coolant fluid?
    The coolant fluid container is marked F and L
    If your reference is above F then its normal because F should be maximum level of the fluid. As in the proper level should be F and below for the coolant fluid, while F and above should be air
    Why that should be the case? Build up in heat result in greater pressure which push that fluid level above the F mark. If you filled the the coolant container up to the brim, then that will be indeed the case, there will always be reduction in fluid level, as long as its not below L mark, then the coolant level should be ok
    If you carefully inspect the coolant container, there is an overspill hole on top. That takes care of excess fluid upon pressure build up, it discharge excess coolant fluid due to pressure expansion
    The best practice in filling up coolant is up to F mark level only
    Sent from my GT-P3110 using Tsikot Forums mobile app
    May 2009
    #28
    sa simpleng pressure test e masshoot siguro ang problema nyan.......
    kahit yung bicycle pump, tire valve, silicone sealant at kung may extra ka na radiator cap or yung pinagpalitan mo na rad cap pupwede na. google nyo po kung pano gumawa ng simpleng aparato para sa pressure test.
    Oct 2013
    #29
    Update mga sirs
    So, last night pinuno ko ng tubig yung expansion tank and radiator. pinaandar ko yung makina for 40mins with aircon. di naman tumaas temp. Sabi ko sa sarili ko pwede ng mabyahe to from Guadalupe to Banawe (Jorge Radiator).
    nakarating ako sa banawe (8am), no aircon. baka itirik ako.
    ang naging solution ni mekaniko, overhaul ng radiator.
    Ok na sia mga sirs. d na sia nagooverheat kahit tirik and araw and may Aircon. salamat sa lahat! The best talaga sa Tsikot!
    #30
    Been guessing eh😁
    well, the radiator cap is the easiest and cheapest suspect to evaluate...
    #31
    Ang symptoms pala ng Toyota Avanza nagbabawas ng coolant, kapag medyo barado na ang radiator neto, which need to be overhauled.
    Sent from my 5015E using Tapatalk
    #32
    Quote Originally Posted by rodetor View Post
    i think this is the same for most other cars.
    Jun 2007
    #33
    Sira na siguro cap ng radiator or worn out na upper radiator hose.
    #34
    Not on my experience with our ride. I encounter overheating that is already near red mark but never runs out of coolant in a radiator even in its reservoir tank. I also end overhauling the radiator when parts like thermostat valve and switch was replaced. The overheating problem diminished when the radiator was overhauled.
    Sent from my Up Snap using Tapatalk
    Jun 2007
    #35
    Yung Overhaul na sinasabi mo ay stop leak lang. Expected naman talaga na mag le-leak ang radiator. Karamihan may leak sealer na nakahalo sa coolant yung iba naman zinc or magnessium na sacrificial anode ang gamit.
    #36
    Quote Originally Posted by desertst0rm View Post
    my concern over leak sealer additives... do they only and really stop leaks, or do they cause radiator blockages as well?
    Sep 2006
    #37
    How much is the typical range for radiator overall?
    #38
    Quote Originally Posted by jdab View Post
    some repairers do not repair plastic-topped radiators. "throw-away" radiators daw.
    others replace (daw) the plastic tubs with brass tubs. don't know if this is true, or if the repair lasts.
    i remember an overhaul quotation of 1800 bucks, but that was years ago.
    surplus? we have no guarantee... that surplus radiator might just turn out to be in worse condition than yours.
    surplus radiators have probably been languishing, dry, in the shop, for some time.
    the corrosion-preventive properties of radiator coolant, have not been enforced on them for some time.
    once installed in your car, they may just "leak like a ligadera".
    brand new, to be sure. 5K or so.
    errr... what's your car and radiator, po?
    #39
    Had the plastic tub replaced with metal on my truck. Still ok until now, around 5 years later. Best thing to do would be to use premixed coolant to make sure corrosion doesn't start. I don't know why, but even with our best effort to get the right ratio of coolant concentrate to water, rust starts to appear a few months after.
    Mar 2013
    #40
    Kung around 80-100k ang mileage mo at working ang both fan, time to overhaul radiator at palit thermostat na din( bka naka stock half open eh). Plastic radiator O/H 5-600 petot (ikaw ang magkalas) kung mayhairline crack better buy replacement 3,500 last year pag auto.
    Check mo lang sir rev engine 2.5k to 3k with out radiator cap pagdahan lumalabas ang tubig mo ah same tayo ng problem Replace head gasket kna din.
Radiator / Overheating Problem
