Page 2 of 29 FirstFirst 12345612 ... LastLast
Results 11 to 20 of 287
    Mar 2017
    The leak could be anywhere. Radiator, hoses, reservoir, water pump, or heaven forbid the engine block. The last time I had a cooling system problem, my mechanic sent me to Keyser in West Avenue QC. Wasn't cheap, but they looked at everything before they gave me a diagnosis and estimate, which was exactly the same as my mechanic's diagnosis.
    May 2011
    Quote Originally Posted by sirkosero View Post
    +1 on the thermostat. My guess its stuck
    Next is rad cap.
    Ask you mechanic to remove the thermostat. If it doesnt overheat anymore, go buy a new thermostat.
    That is assuming your fan is working
    Not all liquid cooling systems are the same. If the car has a three way thermostat, it will overheat even if it did not with a working thermostat removed. Read the description and system operation in the repair manual if you have one.
    Jan 2009
    Quote Originally Posted by mina_nuka View Post
    I doubt that the Avanza has a three-way valve.
    Jun 2005
    Ditto.
    Its an avanza. Dont think its cooling system is anywhere near fancy
    May 2011
    Not familiar with the engine used in the avanza but do you have pictures of the thermostat?
    Jan 2009
    It's top secret. But I think Google has the results you want.
    May 2011
    toyota avanza thermostat - Google Search
    That, amigo, is a three way thermostat😁
    Jan 2009
    That, amigo, is a three way thermostat[emoji16]
    There you go. Good for you. ;)
    May 2009
    a e saglit lang mga bossing...ano ba yang 3-way thermostat na pinaguusapan ninyo? napagiwanan na ata ako ng panahon.
    o baka naman yung ibig sabihin na "3-way" e yung inlet, outlet at yung bypass....hihihi
    napatanong ako bigla ke manong google e ang sagot ba naman e yung pang hvac....
    May 2011
    What was the last thing performed to the engine that might involve the cooling system?
    Ąs per this diagram
    The system should have been bled at two places if at any point the coolant was low or was drained and refilled
Radiator / Overheating Problem
