Results 11 to 20 of 24
    Aug 2014
    Quote Originally Posted by eurostyle View Post
    Opo sir on startup po umiikot agad ang fan kahit hindi pa naka on ang aircon, kaya lagi ako naka aircon ngayon. Ano kaya ang possible na ipapagawa ko dito? Sirang thermoswitch or thermostat na sir? Hindi din pala ako nagbabawas ng tubig, spkonting konti lang kung mabawasan.
    Yes sir ako din po un sa sparkplug, hindi pa ako nakakadaan ng ace para makabili ng socket, sana swak nga ang 5/8 na deep socket.
    nakarekta na ung fan mo sa battery it mean wala na yan relay..Orig wiring pa ba yan? kung hindi bka nairekta na yan dati para di mag overheat or baka nasira na ung thermostat sa radiator kaya nirekta..
    kaya isa lang ang fan mo may HI and Low yan..
    dapat pagstart mo ng engine di pa aandar ung fan then kapag na reach na ung certain heat saka palang aandar ung fan ng Low Speed..then kpag naka on ung A/C automatic aandar din ung fan na naka Hi speed.
    Feb 2003
    UP ko lang etong thread na to, ano kaya problem kapag one of the fan ng radiator/AC condenser is need to jolt or galawin ang blade to start it running? oks pa naman ang speed and blow of air nya. Also never had any issues of overheating pa naman. Concern lang ako baka soon bumigay na sya. where could I buy original Denso Fan kaya aside sa casa?
    Jan 2009
    Quote Originally Posted by Jiggs View Post
    Most likely it's a sign that the motor is about to die. Best to have the motor replaced.
    Happened to my Civic. Changing the motor solved it. I think this is caused by worn-out brush inside the motor. But the motor is typically sealed so you may have to replace it as an assembly. The blade itself, if not damaged, can be transplanted to the new motor.
    Feb 2003
    Thanks any shop where could I buy an original denso fan motor? Preferably near alabang area. Thanks guys
    Jan 2009
    I had mine done at Frigid Zone along Congressional Ave., QC. Just look them up and check their addresses. There are other shops but I don't have any experience dealing with them.
    Aug 2015
    makiki-ride nalang ako dito sa thread na to.
    hi folks,
    ung radiator fan ko minsan maalog at may ingay ang takbo nya instead na pino at tahimik, causing it to slow down and my temp to go up. is this a sure sign na ung motor nya ang problem? palitin na ba or kaya i repair? what else do I need to check. inquired sa coolmate/denso makati kanina and got the ff prices:
    fan motor assembly, original denso - 2,500
    labor - 350
    brand new, original/oem. good deal na no? considering pag nag surplus ako kahit half the price i have no way of knowing ung history. I am scheduled to have this done tomorrow, please tell me what you think.
    btw, altis 2007 ang unit ko. nag iisa lang ang fan ng Altis, ung sa radiator. the shop itself is like 3 mins from my place.
    Sep 2012
    Quote Originally Posted by unmarked View Post
    hi folks,
    labor - 350
    Casa price ba yan or auto supply.
    Ito tip sana mag work for you kung gusto mo brand new motor ipapalit.
    Kapag nabaklas mo yung motor ng fan assemby, hanap ka sa auto supply ng fan assembly na generic pero yung motor is Denso rin or Sanden and tignan mo kung magka size sila.
    The price of the generic fan assembly is just 1,200 to 1,500.
    Ang important lang dyan yung tatangalin mong motor is magkakasya sa fan assembly mo.
    At least yan hindi surplus
    Sent via Tapatalk
    Aug 2015
    Quote Originally Posted by jodski View Post
    Sent via Tapatalk
    Hi sir thanks for the tip. The prices quoted are from Coolmate Makati branch, the/an official distributor of Denso auto parts. parts supply/talyer sila.
    Oct 2014
    May big boost effect ba sa AirCon if magpalagay ng auxcilliary fan sa Radiator front ? TIA.
    Sep 2012
    Quote Originally Posted by Gian Paulo View Post
    Mas mabilis lang lumamig kaysa dati.
    Pero kung ang habol mo is mas lalamig pa ang buga sa vent, ibang usapan na yan at mas magastos
    Sent via Tapatalk
Radiator fan
