Results 11 to 20 of 24
- Aug 2014
- 1
September 8th, 2014 06:45 PM #11nakarekta na ung fan mo sa battery it mean wala na yan relay..Orig wiring pa ba yan? kung hindi bka nairekta na yan dati para di mag overheat or baka nasira na ung thermostat sa radiator kaya nirekta..
kaya isa lang ang fan mo may HI and Low yan..
dapat pagstart mo ng engine di pa aandar ung fan then kapag na reach na ung certain heat saka palang aandar ung fan ng Low Speed..then kpag naka on ung A/C automatic aandar din ung fan na naka Hi speed.
- Feb 2003
- 1,038
November 1st, 2015 11:37 PM #12UP ko lang etong thread na to, ano kaya problem kapag one of the fan ng radiator/AC condenser is need to jolt or galawin ang blade to start it running? oks pa naman ang speed and blow of air nya. Also never had any issues of overheating pa naman. Concern lang ako baka soon bumigay na sya. where could I buy original Denso Fan kaya aside sa casa?
November 1st, 2015 11:50 PM #13
Most likely it's a sign that the motor is about to die. Best to have the motor replaced.
Happened to my Civic. Changing the motor solved it. I think this is caused by worn-out brush inside the motor. But the motor is typically sealed so you may have to replace it as an assembly. The blade itself, if not damaged, can be transplanted to the new motor.
- Feb 2003
- 1,038
November 2nd, 2015 12:03 AM #14Thanks any shop where could I buy an original denso fan motor? Preferably near alabang area. Thanks guys
November 2nd, 2015 12:14 AM #15
- Aug 2015
- 862
March 10th, 2016 05:14 PM #16makiki-ride nalang ako dito sa thread na to.
hi folks,
ung radiator fan ko minsan maalog at may ingay ang takbo nya instead na pino at tahimik, causing it to slow down and my temp to go up. is this a sure sign na ung motor nya ang problem? palitin na ba or kaya i repair? what else do I need to check. inquired sa coolmate/denso makati kanina and got the ff prices:
fan motor assembly, original denso - 2,500
labor - 350
brand new, original/oem. good deal na no? considering pag nag surplus ako kahit half the price i have no way of knowing ung history. I am scheduled to have this done tomorrow, please tell me what you think.
btw, altis 2007 ang unit ko. nag iisa lang ang fan ng Altis, ung sa radiator. the shop itself is like 3 mins from my place.
March 10th, 2016 06:11 PM #17
Casa price ba yan or auto supply.
Ito tip sana mag work for you kung gusto mo brand new motor ipapalit.
Kapag nabaklas mo yung motor ng fan assemby, hanap ka sa auto supply ng fan assembly na generic pero yung motor is Denso rin or Sanden and tignan mo kung magka size sila.
The price of the generic fan assembly is just 1,200 to 1,500.
Ang important lang dyan yung tatangalin mong motor is magkakasya sa fan assembly mo.
At least yan hindi surplus
Sent via Tapatalk
- Aug 2015
- 862
March 10th, 2016 07:40 PM #18
- Oct 2014
- 162
April 4th, 2016 04:03 PM #19May big boost effect ba sa AirCon if magpalagay ng auxcilliary fan sa Radiator front ? TIA.
April 4th, 2016 06:04 PM #20
^ Beat me to it. This "hole" in the Swiss cheese model would've been the last line of defense......
