pag ang vehicle sir ay naipa-camber alignment at perfect na ang wheel alignment specs, hindi na sir yan magbabago, unless
1. change tire rods
camber is measured and adjusted with the front tires are pointed straight ahead, the tie rod does not in any way affect camber. tie rod adjustments only affect the toe
ahaha.. unga pala.. my mistake, tie rods control the toe,
the camber is controlled by an adjustment bolt on the lower A-arm bolts pag coil ang front,
pag torsion bar ang harap, camber is adjusted through the Shims on the upper A-arm...
