Page 1 of 3 123 LastLast
Results 1 to 20 of 59
    Jun 2012
    Nissan Sentra 95 Series 2- M/T B13
    Radiator Overhauled
    Cylinder head gasket replaced
    Hoses replaced
    But a while aago when I turned on my air-con after 1-2kms it overheated. Anything else that I need to look for that could be causing this?
    Aug 2004
    Full overheat, or just a small rise in thermostat reading?
    If it only happens with AC on, check your auxiliary fan. It might not be triggering. But that alone should not cause overheating.
    Jun 2012
    over-heat. as in kumukulo yung tubig sa reserve. tapos sobrang taas ng menor habang umiinit, yung hindi mo na kailangan tapakan ang silinyador.
    Dec 2007
    Hindi dapat kumulo ang coolant. One possibility is you have abusted head gasket which makes the exhaust gas escape through the cooling galleries, hence you have that bubbling effect. Pag ganito situation, uubusin coolant mo through the relief line. Yun lang kasi escape route and then issunod mga coolant hoses mo. Patingnan mo kaagad sa nagoverhaul ng radiator mo.
    Sorry, kapalit mo lang din pala ng gasket. Baka hindi tama ang lapat ng head. A simple observation will prove the above. Kung nauubos ang coolant and if you cannot see any other leaks that causes it, it might be as I explained above.
    Aug 2006
    check your aux fan if it will trigger during overheat. If not, something is wrong with the fan or its socket connector.
    I have experienced poor contact on the aux socket connector on my Lancer EX, same scenario after about 10 KM it will overheat and the aux fan is not working. Replacing the connector has solve the problem.
    Jun 2012
    Napansin ko lang nangyari ito nung nagpalit ako ng compressor ng air-con. Pinalitan ko na din ang hoses saka yung cover nh waterpump ata yun. Pero sabi nila yun yung waterpump.
    Jul 2012
    Pag naka-A/C lang ba nataas temp? Baka naman nag-high pressure iyong a/c mo.
    Jun 2012
    Panong nag high pressure? How to fix it?
    Jun 2011
    Quote Originally Posted by Drumz View Post
    it means barado or madumi condenser mo sir....
    Jun 2012
    Pero nilinis saka nag flush kami nung pinalitan yung compressor sir e. We also changed the valve dryer saka yung lalagyanan ng freon.
    Jul 2012
    Check the condenser fan. Baka inefficient na din yan
    Jul 2011
    pag hindi ka naka-aircon and still nag ooverheat,
    stuck thermostat perhaps?
    Jun 2012
    Tangal na po thermostat sir. Top overhaul na pinagawa ko just to be sure.
    Feb 2009
    some cars overheat if the thermostat was removed. try installing a good working or new thermostat. if the condenser was clogged or restricted, the condenser will be cool or cold (simulated expansion valve)
    Aug 2005
    The overheating has to do with your radiator mostly and its adjacent sub-systems.
    Radiator overhaul where? How?
    What's the condition of your radiator fins?
    Water pump state?
    Jun 2012
    Radiator repair shop ko siya pinaoverhaul. It was disected as in bukas talaga. They de-clogged it tapos checked leaks. Fins are still intact. Water pump is still working. Actually I had it replaced.
    Jun 2012
    Is the condenser the black thing where the freon is placed? Normal ba na nagpapawis ang tubo?
    Aug 2005
    The condenser is the aluminum radiator looking thing in front of the radiator.
    I'm assuming its an original radiator you have or replacement na ito? If so how many years?
    The problem with overhauling is that they really don't solve the problem of scaling on the tube walls, especially if you have run the loop without any coolant.
    No amount of scraping will actually rid the radiator tube walls of the calcified corrosion residue that insulates it.
    Doing so in fact makes it prone to damage and leaks.
    Thing is A/C on or off, your car shouldn't overheat -period. Even if your A/C is working fine, then it certainly isn't the problem.
    In this situation I would surmise that if and when your A/C's condenser is ejecting heat to your radiator, your radiator fins are themselves clogged or simply oxidized (say its over 10 years old) or has been overpainted, that your radiator simply cannot reject the heat.
    Always remember, masmura ang radiator kay sa overhauling.
    Aug 2005
    Here's another thought. Your engine's cooling channels maybe clogged already.
    Aug 2012
    newbie here, ill be needing your help masters
    my nissan sentra 94 ex saloon, pag nadrive ko na siya ng mga around 4hrs with aircon, temperature ng oto lumalagpas na sa kalahati eh, kaya ang gagawin ko is ipapahinga yung oto, for about 30mins, after that ok na ulit temper niya, tingin niyo guys ano kaya prob ng oto?? somebody help po.. normal ba yun sa cars? na tumaas ang temper pag almost 4hrs driving na?
    im not so familiar on how forums starter here.. kung mali po yung pag post po, please correct me, salamat po ng marami, godspeed tsikot.com
Overheat
