Results 21 to 40 of 48
    Sep 2011
    #21
    free po ba check up ng radiator sa mga shops.
    Jun 2005
    #22
    Quote Originally Posted by chito2011 View Post
    yup. but expect na kahit walang sira they will suggest an overhaul dahil barado/madumi tubig/ mukhang may crack at kung anuano pa
    Sent from my Thrill 430x using Tapatalk 2
    Sep 2013
    #23
    i just saw that my radiator has rust in it. there's even a chunk blocking one of the pipes. you guys suggest replacing it?
    tubig kasi gamit eversince nadatnan ko yung vehicle, and that's 11 years ago. gusto ko sana palitan ng coolant (premix) kaso paano ba proseso nito?
    c
    Aug 2005
    #24
    In theory you can have that cleaned using a radiator flush. If that dissolves the sediments you should be fine. Replace with pre-mix coolant.
    Problem is when you "overhaul" you end up poking through the tubes and then risk abrading it, you'd be prone to leaks later and downtime.
    So the prudent sense is to replace the radiator.
    Jul 2011
    #25
    nice thread, kulang na la ng coolant additive package guidelines para sa all Al, Cu/Brass with lead solder.
    Posted via Tsikot Mobile App
    Aug 2005
    #26
    Quote Originally Posted by MrQ5 View Post
    Coolant additive packages are normally applicable for extreme and/or heavy duty applications.
    Any gains are marginal with the current long life coolants actually employed.
    For mixed metal coolant environments, stick with a glycol based coolant. Organic acid based coolants are more prone to cause nominal corrosion in the presence of a current.
    Aug 2012
    #27
    very nice thread. Part 4 na lang ang kulang.
    #28
    I have a seldom used 9yo kia picanto. My sister used it last weekend and experienced overheating. She said she noticed the aircon wasn't cooling for some time and later the red temp sign lit up. She Took it to the nearest gas station and they just topped up the radiator with regular water. The aircon ran back to normal and she was able to go home. I checked today the coolant reserve level and it is full so probably no leaks. It also ran fine this afternoon when I used it for an hour with a/c on.
    Should I have the coolant flushed and replaced? I'm worried the car might overheat again. I just bought 1L of abro ready mix coolant at a hardware shop (recommended over prestone). Is this enough? Can i just add distilled water? Planning to DIY coolant replacement tomorrow
    thanks in advance for your advise
    Apr 2014
    #29
    I flush mo na yan dahil nahaluan na yan nang tap water from the gas station.
    Normally, may knob kang pipihitin sa ilalalim nang radiator para madrain ang laman.
    #30
    #31
    Copy pero ok lang ba 1 liter premixed plus distilled water? Or dagdagan ko ng ibang brand like petron? Checked sa net mukhang 3.8l capacity ng picanto.
    Apr 2014
    #32
    Depends on your preferred concentration level, you might need more. Bukod sa mismong radiator, maglalagay ka pa sa reservoir. also, dont mix different types/brands of coolants.
    Jun 2007
    #33
    Quote Originally Posted by javacardph View Post
    pre-mixed coolant isn't supposed to be added with water (may it be distilled or not), unless during emergency situations. if you are going to replace the tap water, use pre-mixed coolant until the radiator is full.
    Aug 2005
    #34
    Quote Originally Posted by jeDi13 View Post
    You would want to drain it first before replacing the coolant.
    You would want to drain it first before replacing the coolant. Its not just a matter of topping up.
    Apr 2010
    #35
    hello...ask ko lang kung normal ba yung madaling maubos yung coolant doon sa coolant reservoir niya...napapansin ko kasi na ang bilis maubos yung coolant liquid niya.
    #36
    Quote Originally Posted by myas110 View Post
    i don't think so.
    if the cooling system works fine, that reservoir won't need any top-up for a long time.
    i haven't added coolant in my vehicles in over a year now. one of them is 10 years old (topped up once or twice only, from new)... one is 1.5 years old (still haven't topped up)..
    look for leaks. look for under-performing aux fans. look for dirty radiator exterior.
    err... what vehicle, po?
    #37
    check your rad cap. baka sira na din.
    Jun 2013
    #38
    Informative. Thanks!
    Mar 2016
    #39
    Any comments on fabricated brass radiators? Wala kasi available sa casa, mag import pa daw, 2 months waiting time. May leak na kse between sa plastic top at aluminum part. Would you suggest temporize muna with epoxy while waiting or replace na with fabricated brass radiator sa evangelista? Orig radiator 14k, fabricated brass 5k lang. TIA
    Apr 2010
    #40
    Replacement na plastic/aluminum, i think around 3k or less lang ito. Marami sa Banawe
The Definitive Guide to Radiators
