pre-mixed coolant isn't supposed to be added with water (may it be distilled or not), unless during emergency situations. if you are going to replace the tap water, use pre-mixed coolant until the radiator is full.
You would want to drain it first before replacing the coolant.
You would want to drain it first before replacing the coolant. Its not just a matter of topping up.
