Results 1 to 16 of 16
    Feb 2014
    my beater car just turned 16yo (honda city). it's holding up pretty well for such an old car. still got the original hoses (everything's original except for wheel bearings and such). but now i'm a bit worried about hose failure
    you think they'd last 20yrs? LOL. fwiw my coolant temp is 82 degrees. never overheated
    Jan 2009
    At that age, I think it's due for some preventive replacement.
    The fact that it got you worried enough to ask about it here, gives you the more reason to preempt it.
    Jan 2008
    check mo din yung condition ng hose.. sa adventure ko, pag dating ng 100k kms pinalitan ko na yung rad hose.. and kept the old hose as back up
    same dun sa 2002 model altis, pinalitan ko na din and kept the old hose as back up.
    Quote Originally Posted by Vodka View Post
    "pag malambot na."
    squeeze test.
    but one can always replace 'em, for peace of mind.
    my altis hose is 18 years old and it still looks and feels fine.
    Jan 2008
    from my experience, hindi pa ako nasabugan ng hose.. madalas nag develop lang ng pin hole.. resulting to water loss na minsan mahirap ma detect
    Sep 2021
    Agree ako dito.
    My 2 cents, unahan mo na if you have the time and funds naman. I'm not saying it will happen (wag naman sana, right?) but the former's better than it giving you a nasty surprise at an alanganin moment in the middle of nowhere...
    I don't think you're in the same case as an operator of a PUV na kahit kalbo/pudpod na ang gulong, over 2 yrs na yung last oil change, etc. pero wag ka... `bahala na si batman, basta tumatakbo ok lang!'
    Replace it and make the old hose as a back up. Thats what I did with my 12 year old Yaris.
    Sep 2021
    Quote Originally Posted by compact View Post
    Palagay ko baka best na itapon/recycle na lang.
    We used to stockpile yung mga replaced but still serviceable parts din ng mga sasakyan namin, but yung mga non-deteriorating items lang (radiator fan, magwheels, spark plugs etc.) Since goma yan and used na, madudurog lang.
    Baka maging "habitat" pa ng mga daga...
    What do you call this small hose? Bypass hose ba?
    There's some coolant escaping on the top. I already adjusted and re-adjusted the clip but there's still coolant escaping as seen on the pics.
    Imgur: The magic of the Internet
    Feb 2009
    Clean inside the hose and clean the barbed fitting. Then before reinstalling the hose apply a film of silicone sealant. Wait for the sealant to cure before filling with coolant and pressure test to specs
    Jan 2009
    From the picture, it seems that the coolant has begun to permeate through the rubber, likely from micro-cracks due to age. The leak may also be coming from the tube the hose is connected to.... probably a pinhole caused by corrosion (if it's made of metal/aluminum) or a stress crack (if made of plastic).
    The weather is just going to get much hotter in the coming weeks so better nip this problem in the bud.
    ^^ It's apparently called a heater hose.
    My question is , can I safely shorten the hose I'm possibly going to buy?
    Apparently, the only oem heater hose that's readily available is for the 1.8 liter engine (mine is 2.0 ). It's a bit too long so I might have to do some slicing and dicing if I have to make it work.
    Jan 2009
    It should be fine if they share the same I.D. Thought, the O.D. also needs to be near enough for the old clamps to still be able to bite on the hose to keep it snug.
    Replace the coolant while you're at it. This calls for a Honda Type 2?
    Iyon nga pinanghihinayang ko because I just flushed and changed my type 2 coolant several months ago when I installed new oem upper and lower rad hoses.
    I think those are the last stuff I bought from the now shuttered Honda Alabang casa nga.
    Jan 2009
    In that case, as long as you keep the work area clean and avoid contaminating the existing coolant while replacing the hose, you can simply top up what was lost. If the coolant is still fresh, I wouldn't mind reusing it.
    Konti Lang Pala laman Ng heater/bypass hose. I reckon it helped that the vehicle was idle for about 2-3 days.
    It's a good thing I have a small jug of excess type 2 coolant in our garage closet. Otherwise, I'll be doing another jungle hunt around the metro.
When to replace coolant hoses...
