Results 11 to 20 of 135
September 30th, 2007 04:05 PM #11
October 1st, 2007 05:08 PM #12
Check your manual.
Usually the brand doesn't matter so much as long as it contains Ethelyne Glycol (for most vehicles)
If you are brand conscious, use the bigger name brands.
For our situation, it's mixed 50% coolant and 50% distilled water.
This goes into the radiator and the reservoir.
Distilled water is preferred is it does not have impurities that can cause corrosion in your radiator.
Hope this helps.
October 1st, 2007 05:45 PM #13
- Feb 2006
- 771
October 2nd, 2007 12:22 AM #14sirs,
tanong lang po:
i bought my ride po as 2nd hand e kya i plan to DIY draining my radiator and replacing it with new coolant / distilled water mix, how do i do it?
for example ,do i mix the 50% coolant and 50% distilled water on another container and mixing it first OR do i add the 50%distilled water first on the radiator and i add the 50%coolant on top of it?tska mga sir any idea kung ilang liters ang radiator ng Galant 7G?
tska when draining the radiator any tips to look out in doing so?recommended b n tangalin and palinis muna radiator before filling it with the new mixture?any idea if how much?(2nd hand kc kya just want to make sure )
*sir mbiege how to find the drainage ng coolant sa block?
regards po sa lhat ng fellow tsikoters and more power to you guys
October 2nd, 2007 11:47 AM #15
I have VA - 012 Plus Vaico Brand Coolant for all types of cars (European, American and Japanese Cars). Made and packed in Germany. The color is Purple/violet. The coolant is Silicate Free and Nitrite-amin-phosphate-free. It also meets the G12 requirements of the Volkswagen Engine. 1 bottle is 1.5 Liters.
Text or call me at 09177448113 if you're interested.
Thanks.
Jay C.
09177448113
- Jul 2004
- 22
October 2nd, 2007 04:23 PM #17
It depends on the car. You could make a new thread about it. I'm just familiar with my type of engine for my w123 300D that has a block drainage for the coolant. Maybe others have it, maybe not. In case you have one in your car it's good to have it drained there.
Just don't go about removing nuts and bolts...
- Feb 2006
- 771
October 4th, 2007 01:36 PM #18for example ,do i mix the 50% coolant and 50% distilled water on another container and mixing it first OR do i add the 50%distilled water first on the radiator and i add the 50%coolant on top of it?tska mga sir any idea kung ilang liters ang radiator ng Galant 7G?
any ideas about this mga sir?
October 4th, 2007 01:52 PM #19
just add coolant first then distilled water, both will be mixed inside after you've run the engine..
- Feb 2006
- 771
October 5th, 2007 12:06 AM #20salamat po sir BlueBimmer,
follow up lang po any idea kung me nakakalam kung ilan liters ang laman ng Galant 97?
dami salamat po uli
It is repairable. But as oj88 mentioned, it is messy (when repaired) and best used as a last resort.
Liquid tire sealant
