Page 4 of 8 FirstFirst 12345678 LastLast
Results 61 to 80 of 145
    #61
    ^ Honda Type 2 Long Life Coolant is blue and it's not listed. At the very least, that chart is probably outdated.
    This pretty much sums up what my point was. You can probably mix certain types together with little to no cause for concern but doing so will entail varying degrees of guesswork. You can go through that trouble or you can just pop into your car dealer and buy a jug of OEM coolant specifically for your vehicle and let that be the end of it.
    Yes, outdated. And it doesn't include Evans Waterless. One you can't mix w/ any other.
    Jan 2009
    #62
    EDIT: Replied too soon based on something I misread.
    #63
    pwede naman fully drain existing coolant. then wash out the remaining by 3-4x distilled water refill then drain after kew KM or few minutes idle? after doing these steps, pwede na any color of coolant diba? parang mas maigi ito dun sa mga auto na hard to find yun mga coolant nila.
    #64
    If one is able to do total block drains of old coolant, say post-engine-overhaul, & wants no more coolant flushes & changes EVER....go EVANS Waterless.
    *This can't mix w/ waterbased coolant.
    Waterless Engine Coolant - Jay Leno's Garage - YouTube
    Benefits below:
    Apr 2014
    #65
    Benefits below:
    It doesnt degrade?
    What kind of chemical is that? Half life of thousand..
    #66
    Quote Originally Posted by chronicle View Post
    It doesnt degrade?
    Nope...& you can drink it & not die after, too.[emoji4]
    #67
    at magkakano naman yan bro? ^_^
    #68
    Locally? You may ask em, g'ninj.
    Evans Waterless Coolants PH
    #69
    dapat pala bro meron sila nito, para di na need overhaul LOL
    https://www.amazon.com/EVANS-Cooling...ZX4C5HB6X052NK
    #70
    It's still ideal & best applied to a drained block.[emoji106]
    #71
    Hi to all, ano ba magandang coolant for full aluminum radiator? may specific ba for aluminum rad? thanks
    Oct 2005
    #72
    Quote Originally Posted by sleeepy View Post
    Gamit ko Reco-cool coolgard OAT concentrate 450 ea 1 liter sa shell. Good for 5 years. Mix mo nalang ng distilled water or meron din silang pre-diluted 250php ata. Eto info ng coolant. Reco-Cool - Product Range
    Ano kotse?
    Quote Originally Posted by toast View Post
    Ano color niyan?
    Oct 2005
    #75
    Ano color niyan?
    Color Blue
    Oct 2011
    #76
    Hello gurus! Compatible kaya yung pre mix Reco- Cool na binebenta sa shell para sa 2012 Honda Jazz? Wala kayang magiging problem sa aluminum parts? Balak ko sanang itry dahil medyo mahal yung honda type 2 coolant at 770 per liter, at nung tumawag ako sa Honda SPA nung isang araw sabi nung nakausap ko bawal na daw mag takeout ng coolant, sila daw dapat magsasalin. Hassle naman kung kailangan pa pumunta sa dealer para lang mag top up, lalo kung out of way/emergency situations.
    Dec 2009
    #77
    ^plain water is the safest choice..it will dilute your current coolant concentration but it's the cheapest and safest choice
    As far as i know..99% of radiators are aluminum. You can flush the old coolant out and change over to another type. Flushing means completely cleaning out the old coolant
    I would just use honda though. It will last 3yrs or so.
    Oct 2011
    #79
    Although nakalagay sa owner's manual "Never add straight antifreeze or plain water."
    Oct 2011
    #80
    Noted sir dapat talaga ma flush kung magpapalit ng ibang brand/color no, paano ba nila iddrain yung coolant na nasa engine? Para sana walang matirang luma
    As for honda coolant type 1 nakalagay sa container nya replace coolant every 40k kms or 2 years. Kapag type 2 naman after 200k kms or 10 years yung una and then every 5 years na afterwards
Coolant...
