Results 121 to 130 of 135
June 11th, 2024 07:27 PM #121
I owned a Civic FD before.
If losing coolant, check first if there are any signs of leaks around the cooling system... hose, radiator, reservoir, water pump, etc.
Kung walang obvious leaks externally, it could be a blown head gasket. Mausok ba exhaust (white/steamy)?
- Jun 2011
- 1,235
June 11th, 2024 07:36 PM #122Kaya maganda din maglagay ng coolant imbes na plain water. Iyong kulay sa coolant makaka-tulong ma trace kung saan ang leak, singaw, or pawis. Plus iyong tulo ng colored coolant sa parking floor makikita kung saan general area sa engine galing.
- Jun 2024
- 13
June 11th, 2024 07:44 PM #123
Not sure if its normal ba, pero pag kaka start po may usok na white sa exhaust, tapos nung pina check ko po hindi naman din daw blown head gasket. I will check din po again if may leak, ilan days ko na inoobserve hndi ko talaga makita. Yung sa waterpump naman po hindi ko din makapa if meron ba
- Jun 2024
- 13
June 11th, 2024 07:47 PM #124
Naka coolant po ako before mangyari tong mga to, and meron din po ako pwedeng ilagay ngayon kaso may isang mekaniko po kasi na nag sabi sakin palitan buong radiator kaya hindi ko pa nilalagay, ang hirap pag iba iba kasi sinasabi ng mekaniko that's why I tried asking here. Thank you po!
June 11th, 2024 07:48 PM #125
To add, the Civic FD uses Honda Type 2 coolant (blue color). It is long life and it's the coolant my FD had when I bought it new. At the time (2008), Honda dealerships only sold the Type 1 (red color). It's a "pwede na" substitute but you will need to replace it more often. I had to search for Type 2 coolant elsewhere to do my own top-ups.
The coolant color is just a dye they added to make it more prominent when troubleshooting and/or finding leaks. It's not a code or anything else. In other words, mixing different coolants with the same color doesn't mean they are compatible with each other.
There have been horror stories of coolant turning into gel and clogging the cooling system because the wrong coolant was added, even though it was the same color as the OEM.
- 54,226
June 11th, 2024 07:52 PM #126
- Nov 2019
- 1,416
June 11th, 2024 10:28 PM #127Eto yung best chance mo for troubleshooting kung saan ba talaga galing leak.
Also, precaution lang for using distilled water even if it is temporary.
Someone had experiment to compare metal inside distilled water vs coolant for 30 days.
Result is kinalawang pa rin yung metal inside distilled water, yung sa coolant ay walang signs of kalawang.
- Jun 2024
- 13
June 14th, 2024 12:31 PM #128
- 54,226
June 14th, 2024 12:42 PM #129
- Jun 2024
- 13
June 14th, 2024 01:15 PM #130
People Replace Their Gas-Powered Cars Every 12 Years, While Electric Cars Are Renewed Every 3...
Hybrids and EV
