Page 5 of 8 FirstFirst 12345678 LastLast
Results 81 to 100 of 145
    Quote Originally Posted by troytin20 View Post
    Hello gurus! Compatible kaya yung pre mix Reco- Cool na binebenta sa shell para sa 2012 Honda Jazz? Wala kayang magiging problem sa aluminum parts? Balak ko sanang itry dahil medyo mahal yung honda type 2 coolant at 770 per liter, at nung tumawag ako sa Honda SPA nung isang araw sabi nung nakausap ko bawal na daw mag takeout ng coolant, sila daw dapat magsasalin. Hassle naman kung kailangan pa pumunta sa dealer para lang mag top up, lalo kung out of way/emergency situations.
    personally, i won't mix and match them but it's up to you.
    if you're still interested, you can try SamJuansShop (*samjuansshop) • Instagram photos and videos. he sells and sends honda type 2 coolant among other things. sa kanya ako nakabili last time ng baldwin oil filters. he also has a shop at lazada. and sa kanya din ako kukuha ng type 2 coolants in the future
    Oct 2011
    #82
    I forgot to say na ipapa drain/flush ko muna yung existing coolant para hindi maghalo since different brand/color sila
    Thanks for the link sir, will check his stuff too
    nagpa-flush din ako before ng type 2 coolant ng fd2 and mahal talaga.
    iyong nabilhan ko pa dati importer/reseller ng mga honda type 2 coolants na naka 4 liter jugs kaya medyo mura ng konti ang bili ko. pero almost 3k din ata iyong bili ko dati.
    all i can say is, worth it naman kasi hanggang ngayon walang naging problema rad niya.
    Jun 2011
    #84
    Gamit ko pang top up sa 2017 Mobilio, ay Mitsubishi Super Long Life Blue Coolant. 1K Php na 4L container sa Mits. Casa. Made in Japan.
    Feb 2014
    #85
    As far as i know..99% of radiators are aluminum. You can flush the old coolant out and change over to another type. Flushing means completely cleaning out the old coolant
    I would just use honda though. It will last 3yrs or so.
    honda type2 lasts 10yrs
    do coolants expire?
    i was about to top up my truck's rad reservoir when i noticed that the coolant stored in its original bottle isn't as "watery" as i remember it to be. parang medyo viscous na siya w/ crystal like "impurities".
    btw, i'm talking about the oem mitsubishi green coolant. siguro may mga 4 years na din siya naka tago sa cabinet.
    #87
    do coolants expire?
    Diba Mitsubishi Coolant is premixed with a bit of water? If yes, baka nag evaporate yung part water component niya sa tagal?
    https://shopee.ph/MITSUBISHI-RADIATO...996.6908749003
    Yung coolant na ito ng mitsubishi nakasulat talaga na may part water.
    But meron din iba na may nakasulat na 30-50% concentration pero nakasulat lang is may Antirust and antifreeze
    https://shopee.ph/Mitsubishi-Super-L...743.1132981238
    Jan 2009
    #88
    do coolants expire?
    Don't use it. Just get a new bottle.
    #89
    do coolants expire?
    i would be wary of these if there are "solids" present.
    the solids might not dissolve, and cause blockade.
    opted not to use it na lang. daan na lang ako sa suki ko one of these days para bili ng bote.
    thanks mga bro!
    #91
    thanks mga bro!
    para ring expired food.
    just one trip to the loo, and you will be rue-ing the day you ate it...
    Jan 2009
    #92
    Those particulates may be silicates.
    Silicates do have a life, and it's a short one - two years. If left longer, build up inside the radiator begins, and the silicates actually contribute to cooling system problems. Silicate drop out occurs after the coolant has been "spent", and the inhibitors drop out of solution. Silicates are blamed for deposit build up in radiators and heaters, causing engine overheating and poor heater performance. Once the silicates drop out of solution, dissimilar metal corrosion is no longer suppressed, and metal components begin to deteriorate.
    Silicates are deemed to be abrasive in a cooling system, and are blamed for premature water pump seal failure.
    Source: Antifreeze
    Source: Antifreeze
    Hinde pa ba silicate free mga coolant ngayon?
    Jan 2009
    #94
    If it says that it is silicate-free. There are still "regular" low-silicate coolants available.
    And I did say "Those particulates may be silicates."
    Otherwise, unless the coolant container was contaminated through other means, what else can it be?
    #95
    Source: Antifreeze
    thanks for sharing bro
    mas maganda talaga bago lagi coolant
    ill stick with my 20-30k km interval
    Sent from my RMX2020 using Tapatalk
    May 2019
    #96
    Don’t mix coolant of different colors. I personally use Zerex Asian Blue or Honda type 2 for my Element, and just regular green Prestone for my Sonata.
    Jun 2017
    #97
    ok ba to voltronic coolant?
    Apr 2012
    #98
    Noted sir dapat talaga ma flush kung magpapalit ng ibang brand/color no, paano ba nila iddrain yung coolant na nasa engine? Para sana walang matirang luma
    i did DIY coolant flush following this vid. so far ok naman.
    Paano Mag-Flush ng Cooling System ng Montero Sport | DIY Tutorial - YouTube
    ^ not really a knock on him pero nagtataka lang ako medyo ayaw nya ata gumamit ng oem fluids pati sa iba niyang vids.
    Pero informative nga mga diy projects niya sa mga sasakyan irregardless of different makes he has tackled.
    I wouldn't switch on the AC to warm up the engine, the spinning radiator fan will remove the heat build up in the cooling system. this will lengthen the time to open "thermostat"
    coolant change every year is rather excessive.
Coolant...
