Results 81 to 90 of 111
June 1st, 2020 09:20 PM #81
personally, i won't mix and match them but it's up to you.
if you're still interested, you can try SamJuansShop (*samjuansshop) • Instagram photos and videos. he sells and sends honda type 2 coolant among other things. sa kanya ako nakabili last time ng baldwin oil filters. he also has a shop at lazada. and sa kanya din ako kukuha ng type 2 coolants in the future
June 1st, 2020 09:25 PM #82
June 1st, 2020 09:43 PM #83
nagpa-flush din ako before ng type 2 coolant ng fd2 and mahal talaga.
iyong nabilhan ko pa dati importer/reseller ng mga honda type 2 coolants na naka 4 liter jugs kaya medyo mura ng konti ang bili ko. pero almost 3k din ata iyong bili ko dati.
all i can say is, worth it naman kasi hanggang ngayon walang naging problema rad niya.Last edited by baludoy; June 1st, 2020 at 09:47 PM.
- Jun 2011
- 1,081
June 1st, 2020 11:04 PM #84Gamit ko pang top up sa 2017 Mobilio, ay Mitsubishi Super Long Life Blue Coolant. 1K Php na 4L container sa Mits. Casa. Made in Japan.
- Feb 2014
- 2,536
July 23rd, 2020 04:55 PM #86
do coolants expire?
i was about to top up my truck's rad reservoir when i noticed that the coolant stored in its original bottle isn't as "watery" as i remember it to be. parang medyo viscous na siya w/ crystal like "impurities".
btw, i'm talking about the oem mitsubishi green coolant. siguro may mga 4 years na din siya naka tago sa cabinet.
- May 2014
- 1,318
July 23rd, 2020 05:27 PM #87Diba Mitsubishi Coolant is premixed with a bit of water? If yes, baka nag evaporate yung part water component niya sa tagal?
https://shopee.ph/MITSUBISHI-RADIATO...996.6908749003
Yung coolant na ito ng mitsubishi nakasulat talaga na may part water.
But meron din iba na may nakasulat na 30-50% concentration pero nakasulat lang is may Antirust and antifreeze
https://shopee.ph/Mitsubishi-Super-L...743.1132981238
- 52,731
July 23rd, 2020 06:40 PM #89
July 23rd, 2020 09:06 PM #90
opted not to use it na lang. daan na lang ako sa suki ko one of these days para bili ng bote.
thanks mga bro!
high idle RPM at engine start
