Results 51 to 54 of 54
- Oct 2013
- 2,537
June 10th, 2014 12:52 PM #51
- Oct 2013
- 2,537
June 10th, 2014 01:01 PM #52
June 11th, 2014 04:57 AM #53
Depende sa design ng AC system. Nowadays on climate controlled cars (digital AC), compressor is always engaged whenever you turn on the AC button. Several temp sensors monitors cabin temp and adjusts the blower fan depending on the temp setting. Once the cabin reaches the desired temp, fan speed is reduced. If you want to save a bit of fuel, just use the fan mode (blower on, compressor off).
The simpler aircon design which is till found in cars like the Vios uses conventional cycle on and off depending on the temp setting. Just like and old fridge. This design is more economical, although less refined.
The l
BANNED BANNED BANNED
- Jun 2019
- 13
July 15th, 2019 08:43 PM #54I had the same problem on my Honda civic .My air conditioner was blowing hot air for a long time I understood that u should turn out and was necessary to blow out the entire system and renew the freon in the cooling system of the pipes. I decided not to bother and contacted the company http://www.airconservicingsingapore.com/ for repair all types and models of air conditioning from domestic to industrial A/C.
Ah ok. So Wala pa Lang locally released na delicą dito. Pinapakyaw kasi Ng mga outdoor lovers...
Mitsubishi Philippines
