Page 5 of 8 FirstFirst 12345678 LastLast
Results 41 to 50 of 75
    Apr 2010
    #41
    Quote Originally Posted by jodski View Post
    Yes 134 A is the standard nga as required by law.
    My point there is that serpentine type ang evaporator ng 323 1994 model and hindi ganun ka efficient ang cooling ng 134a sa serpentine type.
    Naging pet project ko dati yan eh. Gusto ko magrereklamo sa ginaw pasahero ko dahil sa AC.
    Ito yung sequence ng pinagawa ko para ma achieve less than 10 degrees Celsius ang buga sa vent ng 323.
    Hindi ko kasi pinagawa ng sabay sabay due to budget constraints kaya pinagawa ko ito with 3 month intervals
    1) Replaced bigger condenser fan with custom bracket and additional relays.
    2) Replaced condenser with laminated type na aluminum along with expansion valve and filter.
    3) Replaced evaporator with laminated type ng 13 rows along with expansion valve and filter.
    Optional yung replacement ng expansion valve and filter... mas gusto ko lang talaga palitan agad yan evertime na nilalagyan nila ng solvent yung lines for cleaning
    Sent from my ASUS Zenfone 3 using Tapatalk
    hindi ko pa napapalitan yung evaporator ko (ok pa naman siya nung nagpaayos ako in 2 separate occasions, walang advise sa akin yung aircon mechanic) so chances are, if mapapalitan ko siya ng laminated type evaporator, ay lalamig ang aircon ng kotse?
    and, saan mo pinagawa yung aircon ng tsikot mo?
    Apr 2010
    #42
    jodski: do you have an idea kung ano ang gamit na compressor ng Mazda 323?
    Sep 2012
    #43
    Quote Originally Posted by myas110 View Post
    May improvement yan if gagawin mong laminated type yung evaporator... mas lalamig pa kung laminated din yung condenser.
    Sa Ceejays Las Piņas ako nagpagawa dati
    Pwede yan either Denso or Sanden... hahabulin mo lang yung size at type ng compressor. Check din kung kasya sa bracket mo and kapareho yung grooves na dadaanan ng belt.
    Sa Ceejays naman last resort nila palit compressor. Magaling din sila mag overhaul dun
    Apr 2010
    #44
    I heard of Ceejay's way before (highly recommended from tsikoteers here) and, kahit from Manila pa ako, I even went there 3 years ago para i-check ang aircon system ng 323 ko..... only to find out and told me na kailangan nga nilang palitan yung compressor ko because of the "ting-ting" sound. pero nagulat ako sa presyo for the replacement (brand new one)...so I decided na lang to charge freon na lang since wala akong budget for the replacement.
    but for now siguro, palit muna ako ng laminated type evaporator and condenser.
    BTW: how much ba sila each?
    Jun 2017
    #45
    Mga bossing pa-help naman po. Newbie here in tsikot. Yung 2009 hyundai tucson crdi ko nakita kong may bahid ng langis yung hose coming from compressor going sa bakal na connecting sa expansion valve. Sabi nila may leak pero malamig parin po ang buga ng A/C ko kahit 1 week ko nang nakita yung suspected leak. may slight hissing sound din sa loob pag nasa #2 or 3 sya. Ano kaya problem ng aircon ko. worried lang ako baka masira compressor ko Is this really a leak? Thanks Y'all!!!
    Jan 2010
    #46
    baka may makasagot din sa problema ng tsikot ko. noong una, kapag nagrrev tsaka nagkaka-aircon. ngayon, kahit tuloy tuloy na 60 ang takbo ko, wala pa rin. this was after ko pang ipalinis ang aircon ko. balak kong ibalik sa shop na pinagdalhan ko before, pero gusto kong malaman kung anong possible cause (and solution), or at the very least, ano ang mga dapat ia-check kapag ganito ang problema. minsan kasi kahit yung mekaniko hindi rin lahat alam, so it would be best if I can have full information.
    thanks in advance.
    #47
    Quote Originally Posted by itoangtama View Post
    thanks in advance.
    too many possibilities. practically every component is suspect.
    just bring it back to them, po.
    let them figure it out.
    Sep 2012
    #48
    Depeds sa supplier kung saan mo kinuha.
    It can go around 2,300 and up.
    Evaporator na nakuha ko dati aroung 5k ata
    Jun 2008
    #49
    * ian: May singaw yan kaya may oil trace. May kunting oil na sumasama sa circulation ng refrigerant. Gradually mauubos ang charge, iinit ang buga ng hangin.
    Sent from my NX549J using Tsikot Forums mobile app
    Apr 2010
    #50
    pero for now, maybe I'll check to the aircon mechanic for some leak tests soon.
biglang nawala lamig ng aircon!!!
