Page 7 of 8 FirstFirst ... 345678 LastLast
Results 61 to 70 of 75
    #61
    Sakit ata talaga ng Altis ang AC
    2014 Altis ko naka ilan palit ng compressor. Buti under warranty.
    but as i recall, your problem was not the compressor, but something else.
    the 2003 altis i drive, still has its original compressor, working.
    #62
    I don't know nga e. But they replaced the compressor thrice Though I think there's a batch of 11th gen with compressor issues kaya they just kept on replacing the compressor and not checking for other problems
    Jul 2016
    #63
    2003 altis doesnt use clutchless type compressor.
    Ung issue ni TS, cathy and my opismate's have all the younger gen 2012 clutchless type comp.
    #64
    Quote Originally Posted by Janemar View Post
    lucky me!
    which brings me to the question... why shift from clutched- to clutchless..? what advantage does clutchless offer?
    Feb 2014
    #65
    hmmm... so hindi pala reliable mga clutchless? or is it just bad engineering on those particular compressors
    Feb 2014
    #66
    lucky me!
    supposedly to prevent the thunk when clutch engages and prevent the sudden loss of power. but it's not an issue on modern engines. it's not even an issue even on "weak" 1.3L vios or cities
    Jul 2016
    #67
    lucky me!
    Not sure sir, but atleast dalawa na kilala ko nasiraan on their low mileage clutchless altises.
    Same concept why sikat na sikat ngaun ang "inverter" type ACU. To gain a little effiency by just using right pressures to produce desired cooling temp.
    2nd na lang ung refinement, not hearing/feeling tick sound of clutch engagement.
    Aug 2004
    #68
    Eto may onting primer about how a clutchless compressor works: Variable Displacement Compressor - How it Works | AxleAddict
    Baka in most cases ok pa ang compressor itself but the problem is with the actuator that adjust the displacement of the pistons inside. Kung external actuator baka repairable pa. If internal malamang palit buong unit na.
    Jul 2016
    #69
    In theory, yes sir pede pa nga palitan ung particular part na nag cause ng failure like you mentioned.
    In reality, walang nag rerepair so far mapa banawe or kahit sikat na shops like si Denso aircon or si frigidzone, lahat sila palit isang buong compressor gusto. Price will vary between 32-35k nuon outaide casa.
    #70
    may simptomas na failing na ang condenser fan ko pala kaya hilaw na ang lamig
biglang nawala lamig ng aircon!!!
