Results 41 to 50 of 75
June 15th, 2017 07:38 AM #41
hindi ko pa napapalitan yung evaporator ko (ok pa naman siya nung nagpaayos ako in 2 separate occasions, walang advise sa akin yung aircon mechanic) so chances are, if mapapalitan ko siya ng laminated type evaporator, ay lalamig ang aircon ng kotse?
and, saan mo pinagawa yung aircon ng tsikot mo?
June 15th, 2017 07:47 AM #42
jodski: do you have an idea kung ano ang gamit na compressor ng Mazda 323?
June 15th, 2017 09:04 AM #43
May improvement yan if gagawin mong laminated type yung evaporator... mas lalamig pa kung laminated din yung condenser.
Sa Ceejays Las Piñas ako nagpagawa dati
Pwede yan either Denso or Sanden... hahabulin mo lang yung size at type ng compressor. Check din kung kasya sa bracket mo and kapareho yung grooves na dadaanan ng belt.
Sa Ceejays naman last resort nila palit compressor. Magaling din sila mag overhaul dun
Sent from my ASUS Zenfone 3 using Tapatalk
June 16th, 2017 07:24 AM #44
I heard of Ceejay's way before (highly recommended from tsikoteers here) and, kahit from Manila pa ako, I even went there 3 years ago para i-check ang aircon system ng 323 ko..... only to find out and told me na kailangan nga nilang palitan yung compressor ko because of the "ting-ting" sound. pero nagulat ako sa presyo for the replacement (brand new one)...so I decided na lang to charge freon na lang since wala akong budget for the replacement.
but for now siguro, palit muna ako ng laminated type evaporator and condenser.
BTW: how much ba sila each?
- Jun 2017
- 6
June 16th, 2017 06:20 PM #45Mga bossing pa-help naman po. Newbie here in tsikot. Yung 2009 hyundai tucson crdi ko nakita kong may bahid ng langis yung hose coming from compressor going sa bakal na connecting sa expansion valve. Sabi nila may leak pero malamig parin po ang buga ng A/C ko kahit 1 week ko nang nakita yung suspected leak. may slight hissing sound din sa loob pag nasa #2 or 3 sya. Ano kaya problem ng aircon ko. worried lang ako baka masira compressor ko
Is this really a leak? Thanks Y'all!!!
- Jan 2010
- 16
June 17th, 2017 09:49 PM #46baka may makasagot din sa problema ng tsikot ko. noong una, kapag nagrrev tsaka nagkaka-aircon. ngayon, kahit tuloy tuloy na 60 ang takbo ko, wala pa rin. this was after ko pang ipalinis ang aircon ko. balak kong ibalik sa shop na pinagdalhan ko before, pero gusto kong malaman kung anong possible cause (and solution), or at the very least, ano ang mga dapat ia-check kapag ganito ang problema. minsan kasi kahit yung mekaniko hindi rin lahat alam, so it would be best if I can have full information.
thanks in advance.
- 54,205
June 17th, 2017 10:45 PM #47
June 18th, 2017 12:04 PM #48
- Jun 2008
- 1,741
June 18th, 2017 12:24 PM #49* ian: May singaw yan kaya may oil trace. May kunting oil na sumasama sa circulation ng refrigerant. Gradually mauubos ang charge, iinit ang buga ng hangin.
Sent from my NX549J using Tsikot Forums mobile appLast edited by weisshorn; June 18th, 2017 at 12:27 PM.
June 20th, 2017 08:43 AM #50
Very informative discussion guys. Thanks a lot!
Liquid tire sealant
