When you had it "fix" instead of "remove and replace" failed parts.
It is neglect.
Actually automotive technicians here are trained this way. To remove and replace.
Maybe you are fortunate to have a section that will calibrate, certify, and re certify parts.
How many mechanics have proper training in metrology?
You are very lucky you have access to proper instruments that you can repair a part
back to reliable use.
As for us out there, we remove and replace and that is it.
Surplus or oem, so long that it still works.
nope, all we had was ordinary mechanics' tools. we tried to fix parts that we could, so we can use them again. you know... clean, solder or weld, un-bend, bend, adjust clearance, sandpaper, re-paint.. nothing major. no, we did not re-manufacture them. and we did it for two reasons: first, because it was challenging and fun; and two, we didn't have money to buy new parts. heh heh.
just like dr. belo, fix, augment, cut, smoothen, reduce, repair. nothing much of replacement![]()
tanong lang, dapat ba mag-overheat ang makiina kung naka-rekta ang compressor (i.e. always engaged)?
dati kasi ganyan yung kotse ko pero hindi naman nag-overheat.
kaya sa palagay ko sa engine cooling system ang problema. hindi kaya isustain ang load ng aircon.
at sa pagkakaalam ko yung aux fan sa condenser mostly. may sariling fan ang radiator. kung sira ang aux fan, hindi lalamig yung hanging sa aircon.
mawawala lang lamig ng air conditioning kung magooverheat. hindi magooverheat dahil nakareckta compressor. nagkataon lang siguro sa oto ng ts. maghigh pressure a/c kung overheat.
cooling system lang talaga problem.
They replaced the water pump, so they finally found where the problem started.
I have seen this countless times, once at start up the pump breaking right in front of me,
Corroded water pumps which may be due
To that kwentong barbero, `only use water.` Nakaka sira daw ang coolant.
