Results 1 to 10 of 23
- Mar 2007
- 79
December 20th, 2012 05:34 PM #1Sir, what could be the problem pag namamatay ang engine when the aircon is on? The scenario is this, sa unang bukas ng a/c ay oks naman ang idle, actually tumataas pa nga po ng konti ang rpm which is good. But after around 10 minutes of driving, namamatay ang makina kahit pa naka-idle lang.
Hopefully, hinde po ganun kagrabe ang sira at masolve po asap ang problem...mahirap din po magdrive pag mainit ang panahon.
By the way, ride is honda. Your immediate response will be very much appreciated. TY
December 21st, 2012 10:36 AM #2
BANNED BANNED BANNED
- May 2012
- 142
December 22nd, 2012 03:55 PM #3parang masyadong mababa ang idle mo. try mo increase by 100rpm, test. increase by another hundred, test again. idle speed should not be below 500rpm. most engines will increase the idle when the ac is started.
bro glenn's advice is worth checking. ipa check mo ang bearings using an ultrasonic detector.
- Mar 2007
- 79
December 23rd, 2012 12:45 PM #4Sir, maayos naman po ang rpm ng auto, tumataas pa nga po menor pag inopen na ang a/c. The problem occurs pag medyo matagal ng nakaopen ang aircon, namamatay na po ang engine. Sabi ng isang mekaniko na tumingin ay nasobrahan daw po ng karga ng freon...kasi daw umiinit agad yung parang mga tubong dinadaluyan ng freon kaya hinde kinakaya ng engine...possible po ba ito?
Ang solution nya ay babawasan daw nya ng freon para hinde na mamatay ang makina kahit pa matagal na naka-aircon...tama po ba tong gagawin nyang ito?
- Jul 2010
- 570
December 23rd, 2012 03:03 PM #5Kung nangyari ito after mag pakarga ng freon ay possible high pressure nga mag cause ng problem. EFI or Carb type engine mo?
- Mar 2007
- 79
December 23rd, 2012 05:44 PM #6
- Jul 2010
- 570
December 24th, 2012 01:39 AM #7Pa check mo na lang sa aircon specialist. Medyo malayong carb adjustment kasi kapag umiinit lang saka magluko.
- Mar 2007
- 79
January 17th, 2013 11:50 AM #8Sir, just an update. Already brought my ride to a car specialist then had my ac checked. Ang diagnose nila kaya daw namamatay ang engine pag matagal nang nakabukas ang aircon ay dahil daw sa busted compressor kaya umiinit ng sobra ang mga hoses at hinde na daw kinakaya ng engine...tama po ba to?
Kasi nung pina-on ang ac ay maingay na daw ang bearing. So his immediate recommendation is to replace my compressor kaso may kamahalan kaya hinde ko muna pinagalaw...and I want to seek some advices here first bago ko po papalitan baka kasi may mas cheaper & reasonable solution but for long term din naman.
Ang tanong ko lang po, pag maingay ba ang bearing ay dapat palitan na agad ang compressor, hinde po ba pwede irepair lang or palit lang ng bearing kung sakali? TY
January 17th, 2013 11:55 AM #10
Depends on which bearing pinaguusapan. If yung clutch bearing lang pwede palitan. Pero kung internal bearing na ang stuck up either overhaul compressor (not recommended per my experience) or palit na talaga.
Worst case aapoy ang engine compartment mo when the friction heat ignites something flammable
Daming issue ng SU7:grin:
Xiaomi E-Car
