Sir, just to give an update, I brought the car to another aircon shop...and their suggestions to eliminate the high pressure issue, ay dapat daw palitan ng mas mahabang condenser un auto. Yung compressor naman daw ay maayos pa, normal lang daw ang ingay ng bearing. Ilang beses na daw sila naka-encounter ng same problem at pinapalitan lang nila ng mas mahabang condenser at hinde na daw bumabalik pa ang clients nila, meaning...nasolve daw ang problem.
Ang tanong ko lang sir, alin po ba sa dalawa ang mas possibleng solution when it comes to high pressure...palit compressor or install a wider condenser? Baka po kasi magkamali ako ng desisyon pero yun pala ay palit ng mahabang condenser lang ang makakasolve or the other way around naman...baka yung compressor pala ang makakatapos sa problema. As much as possible, I want to go to the much nearer and feasible solution dahil medyo madugo po sa budget kung pagsasabayin ko ang dalawa.
Hopefully, I could get solid suggestions from our expert tsikoteers what to prioritize between the two. Thank you
