parang masyadong mababa ang idle mo. try mo increase by 100rpm, test. increase by another hundred, test again. idle speed should not be below 500rpm. most engines will increase the idle when the ac is started.
bro glenn's advice is worth checking. ipa check mo ang bearings using an ultrasonic detector.
