Page 4 of 5 FirstFirst 12345 LastLast
Results 61 to 80 of 91
    Oct 2004
    #61
    Just want to share this link for troubleshooting an overheating engine:
    http://www.troubleshooters.com/tprom...210/200210.htm
    Hope it helps.
    #62
    Quote Originally Posted by NightRock
    Up ko lang.. even after changing water pump ganon pa pin it become worse in fact.... it lost the power.. it is now with Ferdie cousin of Afrasay I hope he can solve tha problem
    Pa-update naman what happened na with your problem bro.? How was it solved...
    #63
    hindi pala water pump ang problema... yung cooling system mismo radiator medyo luma na at yung cap
    Jun 2005
    #64
    yung sa akin din l300 gas, tumtaas ang temp sa 1/2, tapos pag inapakan ko na gas, nakakarinig ako ng ping or tik tik.. sa makina, pero pag di mataas temp. ok naman o kaya pag naka 1st o 2nd gear ako, wala na sya thermostat. sabi ng mekaniko, overhaul na radiator o palit na rin water pump.
    Feb 2006
    #65
    my ride is L3 4d56 engine
    sofar i replaced the ff:
    3 row radiator:ever cool
    aux radiator fan
    layed down condenser in order to give more air to the radiator
    eversince it never over heats again.
    hth
    Feb 2007
    #66
    just bumping an old thread...
    Im planning to replace the stock radiator of my L300 with a 3 row radiator from Evercool, any idea how much does it cost nowadays?
    Thanks!
    Oct 2007
    #67
    Quote Originally Posted by momoyster View Post
    i also experienced that before when driving our '89 pajero at high speed. bagong overhaul ang radiator but the temp would keep on rising as the speed went beyond 100kph. at 120 kph-3000 rpm (sagad na talaga yung makina), the gauge would already be pointing beyond the halfway mark, 3/4 to be exact. slowing down to 100 kph would bring it back to the half point. stuck-up yung thermostat, lime deposits caused thermostat failure
    This is normal with dirty cooling systems.
    lime deposits caused thermostat failure[/quote]
    This is caused by running a raw water cooling system. ie tubig ang laman
    ng radiator.
    Oct 2008
    #68
    Andito lang pala kayo! I hope someone can help me with my problem also.. I've read all the posts here.. From page 1 till here I am posting.. I have a 97 L200 4D56 Engine.. When running on a freeway.. Ok lang temp nya.. Problem starts sa traffic.. Even if it's a short traffic tumataas! Hanggang 3/4 and still moving closer to the warning sign (red) and kasi takot ako mag overheat I usually turn off the a/c and when I get home when I check my reservoir ubos ang h20.. I have a new water pump, new head gasket, new camshaft, new rocker arm assy, overhauled my rad, rad cap is still new, valve clearance is correct, belts are new.. It doesnt have a thermostat anymore.. Yung reservoir ko medyo sira na kasi hindi na sealed.. May singaw na.. Havent checked on the clutch fan since I dont have any problem when running * high speed.. But the temp rises when you run uphill..
    Can anyone please help me?? TIA
    Oct 2007
    #69
    Quote Originally Posted by pierced View Post
    This normal on a dirty cooling system but please put back a thermostat to
    make your system complete. You would also need to use premix coolant to hopefully retard the corrosion in your system. Ang problema kasi it would be
    very difficult to remove the scaling in your cooling system without the proper equipment.
    The use of raw water destroys your cooling system as water is the universal solvent, in simplest terms nilulusaw ng tubig and mga bakal sa makina mo. And your cooling system is the weakest link in the chain in your engine (napakanipis ng pyesa rito).
    Ang problema maraming magaling na mekaniko sasabihin sa iyo na personal preference daw ika kung tubig ang gamitin mo pare pareho yan.
    But the reality is maintenance is all about protocols, nakakasunod ka ba sa
    requirement ng engine for a trouble free operation.
    Your situation now is how you can control the corrosion in your cooling system.
    Oct 2008
    #70
    Quote Originally Posted by mark_t View Post
    Thank you sa mga suggestions and advices.. I'll try to do this pag may budget na.. It'll cost me around 3-4k here in Cebu.. With the rad overhaul, thermostat, and reservoir..
    Oct 2007
    #71
    Better if you act now. Buy a premix radiator coolant and drain your cooling system, clean what ever that you can clean like the hoses to the reservoir, reservoir etc. What is
    important is try to stop the corrosion now. Kailangan matanggal mo na ang raw water as soon as possible kasi wala itong anti corrosion properties. After let us say 10,000kms of using this coolant palit ka uli coolant then that will be good for another 40,000kms. You Dont need to overhaul that now just do what is necessary. Maybe 1000pesos will do the job kasama na thermostat. Kung ako mechanic mo yan ang papagawa ko sa iyo para matuto ka then papa observe ko sa iyo mangyayari for the next 6 months. Hopefully hindi pa bulok ang cooling system mo. Kung kailangan mo magdagdag ng tubig use absolute, wilkins or other distilled
    bottled water.
    Dont worry kung bulok na cooling system mo, mabubutas naman yan at puede mo na pa overhaul.
    Oct 2008
    #72
    Ok.. I'll have my rad overhauled this week na.. Thermostat and H2O reservoir next week cguro since I still have to order sa El Dorado and + shipping pa dito sa Cebu..
    Oct 2008
    #73
    Na check na ng cousin ko L200 ko and he told me to change the rad cap since wala na pala check valve nito kaya bumabalik ang h20 sa reservoir.. Sana ok na after nito..
    May 2009
    #74
    saan po ako makabili ng radiator sa pajero namin 2.5 4d56
    #75
    Same here i bought surplus 4D56 turbo engine (45k) installed to my Besta 98 body coz its stock 2.2 engine blown down. Upon replacing temp is rising up, remedy I did was to replace & oversize the radiator with big one. Alas! overheating solved.
    Until now it's running cool! That was 4 yrs ago imagine that!
    Nov 2007
    #76
    mga sir.
    experience ko lang sa engine ng 4d56 is that the main culprit pag tumataas ang temp nya ay yung CYLINDER HEAD nya ay "NABIBINGKONG"(nag wawarp?) thru time.dont know why?
    Meaning kelangan nyu pong pa machine shop "REFACE" yung cylinder head nya.
    F.Y.I own fb L300 L200 lahat po cla nagmanifest ng ganun symptoms. Tinanggal ko na thermostat, new radiator etc. ganun paren.
    Nung pina reface ko ayaw na umakyat nun temp guage kahit 100kmh takbo mo
    Sep 2006
    #77
    Hi, guys ok lang ba na i direct ko na yun fan clucth ko kasi nag oover heat yun spacegear ko 2.8 intercooler pag up hill ang byahe ko
    #78
    How about the water jacket of our engine?
    #79
    WArping of cylinder head is the cause of thermal fatigue of the engine metal. How? when the engine overheat, the driver immediately pour water into the radiator. Furthermore,
    cylinder heard warping is due to not observing the proper torque and torque sequence of the cylinder head. When the engine overheat, wait for sometime for the engine to cool down before pouring water to the radiator. Or pour hot water into the radiator, not cold or water directly from the faucet. Pa rin tao, magpagod ka 1/2 day then immediately take a bath, what would happen to? what would U feel. Ganoon din po engine. Thats what we call thermal stress of the engine metal kya nagwarp.
    #80
    Please check the radiator fan blades. A radiator fan blades that is made of PLASTIC has a tendency to straighten and have no power to extract heat from the radiator specially at high speed. that why your water temp rises up during high speed.
4D56 Overheating
