Results 41 to 50 of 91
- 3,754
November 6th, 2004 07:04 PM #41Originally posted by afrasay
hehe bakit naman old owner, matanda na ba si Hap... :D
- 3,754
November 7th, 2004 01:12 PM #43sa age lang naman yon hehehe pero sa itsura .. Very Young hehehe Asan na ba yon??
November 7th, 2004 04:07 PM #44
Dieseler,
Somehow the coolant helped. Hindi na tumataas yung temp and up to now hindi pa ako nababawasan ng tubig.
I was using 100% H20 na pala without me noticing.
Thanks
November 11th, 2004 03:46 AM #46
madami na po ako nkikitang L200 na may auv fan sa harap. katabi po ng oil cooler po ba un? pero ung strada po ata may aux fan na agan. bka mka2long ito
November 11th, 2004 06:23 AM #47
sa intercooler yun aux fan. I think it wouldn't help that much on the engine. please correct me if I'm wrong guys.
- 3,754
December 4th, 2004 08:53 PM #48Up ko lang.. even after changing water pump ganon pa pin it become worse in fact.... it lost the power.. it is now with Ferdie cousin of Afrasay I hope he can solve tha problem
December 5th, 2004 07:52 PM #50
hi guyz!ask ko ko lang..
bakit ganun?ung delica ko,(4d56t,automatic)
this past 1-2 yrs,kapag naka-idle/stuck sa traffic di lumamlampas sa 1/4 ng temp. guage..pero pag tumatakbo na(lalo na pag 80-100 kph) ay may tendency siyang lumampas sa 1/2-3/4 ng gauge until such time na iilaw ung warning na "a/t temp" tapos almost last line before red na ung temp. guage.papaakyat lang sa tagaytay overheat na..
nababa ko na ung radiator,calibrated,checked na ung water pump,nagawa ko na halos lahat sa makina,e..pero ganun parin..
ok naman po fan belts ko..katunayan po,radiator ko,3 layers that holds almost 6 liters of water/coolant..pinaalis ko na yung "thermostat" sa loob ng water pump..clutch fan is ok..the auxiliary fans(1 sa radiator/condenser & 1 on the 2nd condenser)are both ok..2 oilcooler (1 for engine,1 for the a/t) ok din,d naman barado/butas..may konting tulo ng oil sa turbo,ok naman lahat. maganda cooling nitong van,pang hot climate (swerte sa auction,e..conversion lang d maganda )
masmabilis nga din po magoverheat din kapag paakyat ako stuck in either 1st/2nd gear.do you think po transmision ko na may prob?
nga pala din po,pag nagchecheck ako ng fluids/oils,napapansin kong amoy sunog ung a/t fluid ko..and ung clutch fan ng van pinafixed ng father ko kasi nasulsulan siya..alin po bang mas maganda, dito sa climate natin..ung freewheeling/fixed?
thanx po!
Xiaomi E-Car
