Results 1 to 10 of 26
March 14th, 2005 11:35 AM #1
I tried using 3M brand Rubbing compound to erase those watermarks sa windshiled and other windows ng AUV ko. What i did was, using a pranela (wet), i put a small amount of 3M rubbing compound, then apply it to the glass (circular motion) , at saka punas agad ng dry pranela.. To my surprise, maganada ang kinalabasan.. almost nawala na yung waterspot na di makuha ng mga glass cleaner.. siguro konting tiyaga lang sa pag punas nito ay 95% tanggal ang spots.. Yun nga lang medyo nakakapagod.. pinawisan ako ng husto,,pero okey lang sulit na sulit naman.. Parang Pina detail mo na rin.. Thansk sa Tsikot .com, dito ko nalaman na okey palang gamitin ito..
March 14th, 2005 11:41 AM #2
CAREFUL in using rubbing compounds...
btw, keep away from pranelas as much as possible. they can do more harm to your paint's finish.
moving this thread to MORE THAN LOOKS.
March 14th, 2005 12:12 PM #3
Thanks, but i only used pranelas sa glass windows, but sometime sa body rin.. So tlagang mag maganda gamitin ay Chamois..any particular brand for it? we have several of those sa auto supply,,, and i usually settled sa medium price brand..
March 14th, 2005 12:34 PM #4
chamois? depends on how you use it. you can either use the glide or patting technique. this is to minimize friction between the chamois & the paint (and reduces your probability of scratching it).
use a microfiber towel / terry cloth / 100% pure cotton towel instead.
March 14th, 2005 03:42 PM #9
Madaming MF ngayon sa shop, tignan nyo nalang, mas mura pa yung current supplier.
FrankDrebin GuestMarch 14th, 2005 03:46 PM #10
Ipa-windshield detail mo na lang sa BigBerts. Mas mura pa at garantisadong tanggal ang matsa. Hindi pa sasakit ang braso mo sa kakapahid. Dami ko na ring nabiling WS detaling products isama na yung strip-it na worth P700 eh minimum result lang ang nakuha ko. (payat kasi ako kaya mahina ang paghagod ko :D)
USD 70,000 ... sold in PH for 5M pesos ... Ford Bronco Outer Banks with Sasquatch package ... ...
2020 Ford Bronco
