I read kasi on a research somewhere na the chemicals on a can of Coke can remove top rust. Being curious and suspicious at the same time, sinbukan ko. Nagulat ako when it worked. Tapos, na-curious ako ulit, tinira ko yung dirt sa muffler ko using Coke. Abah, na-tanggal nung Coke.
After that experiment of mine, dehins na ako umiinom ng Coke or Pepsi. Sprite or 7-Up na lang kasi less ang chemicals at natural spring water ang ginagamit.
yung sa Crosswind ng Dad ko I had to remove hard water marks na 3 years nag build up. As in may film na on all glass windows. Whole day ko ginawa with another guy. Used a glass stripper I bought from COncord. I had to use the liquid solution as a rubbing compound, i.e lagay sa basahan rub sa glass (a very small section at a time) til matanggal yung water marks. I was able to do it. Mga 300php yung stripper.
yung sa vinegar ba kailangan bang ulit-ulitin? ilan times? ginamit ko heinz distilled pero after 2 applications parang wala pang nababawasan sa spots. what I did was pour small amount on clean rag and wiped onto the glass. rinse with water then applied again. pero I stopped na kasi parang hindi naman nabawasan.
