Results 1 to 10 of 98
June 10th, 2013 12:33 PM #1
Rainy season is here, and madalas na gamitin ang wipers and windshield washers natin.
Do these product perform better than regular water? Do these fluids have shelf life na may drain interval pa?
Hingi ako suggestions..
June 10th, 2013 12:37 PM #2
the washer fluid helps in cleaning the windshield lalo na kung madumi. it also lubricates.
- Jul 2011
- 1,711
June 10th, 2013 12:40 PM #31. Wag ka gagamit ng tubig poso sa water reservoir.
2. Kung OC ka sa water spots, gumamit ng distilled water (ex. Wilkins)
3. Lagyan mo ng konting JOY ung tubig, pampadulas din un.
Ung wiper pag hindi na pantay ang hagod, palitan mo na, mas mura ang wiper kesa ma-accident ka.
Wag iinom ng Beer/Gin/Whiskey para uminit ang katawan kung gusto mo mag-drive pag tag-ulan.
June 10th, 2013 12:44 PM #4
Other put Shampoo/Liquid Detergent solution as a washer fluid...Is this safe and effective?
June 10th, 2013 12:45 PM #5
Eto gamit ko
After cleaning/car wash. Yung dilaw ipapahid sa glass then let it dry for a few minutes.. maghahaze yung glass then ipopolish sya manually.. medyo mahirap ipolish kelangan talaga may pwersa... ipektib talaga sya.. you will notice the water droplets slide and roll over like there's a coating of oil sa glass pag umuulan.. yung blue naman na liquid, half nun ihahalo sa washer reservoir.
I heard mas ok daw shampoo or Joy liquid dishwasher isama sa washer reservoir, how true?
Ang problem ko ngayon, yung wiper blades ko kakapalit ko lang last April during the MIAS kaso maganit na ngayon, nilalagyan ko ng Glaz No Squix kaso after a while maganit na naman..
June 10th, 2013 12:45 PM #6
^ Won't the degreasing chemical of Joy strip the wiper blade off its natural oil in the rubber?
I just use filtered drinking water. When the car was new, I spent a lot of money on Wilkins.
June 10th, 2013 12:56 PM #7
June 10th, 2013 01:10 PM #8
I just buy the Toyota OEM washer fluid and use it on our cars. Cost is around P 100 or so if i recall correctly (1L).
June 10th, 2013 01:34 PM #9
I use Microtex Wiper Bead. 190 ata for 2 liters. No need to dilute. Effective in both cleaning and coating the glass with a bit of rain repellant. Booster ng Stain Guard.
June 10th, 2013 02:04 PM #10
I need to buy new tires. Why can't I find Michelin PS4 anymore? What they are offering is the...
Finding the Best Tire for You
