Page 1 of 4 1234 LastLast
Results 1 to 20 of 111
    Jul 2011
    Rainy season is here, and madalas na gamitin ang wipers and windshield washers natin.
    Do these product perform better than regular water? Do these fluids have shelf life na may drain interval pa?
    Hingi ako suggestions..
    the washer fluid helps in cleaning the windshield lalo na kung madumi. it also lubricates.
    Other put Shampoo/Liquid Detergent solution as a washer fluid...Is this safe and effective?
    Mar 2012
    Eto gamit ko
    After cleaning/car wash. Yung dilaw ipapahid sa glass then let it dry for a few minutes.. maghahaze yung glass then ipopolish sya manually.. medyo mahirap ipolish kelangan talaga may pwersa... ipektib talaga sya.. you will notice the water droplets slide and roll over like there's a coating of oil sa glass pag umuulan.. yung blue naman na liquid, half nun ihahalo sa washer reservoir.
    I heard mas ok daw shampoo or Joy liquid dishwasher isama sa washer reservoir, how true?
    Ang problem ko ngayon, yung wiper blades ko kakapalit ko lang last April during the MIAS kaso maganit na ngayon, nilalagyan ko ng Glaz No Squix kaso after a while maganit na naman..
    Oct 2011
    Quote Originally Posted by stickers View Post
    Eto gamit ko
    Sir, yan din dapat gamitin ko elevo rain fly and elevo watermarks remover. pero binili ko ung Glaz stain out and stain guard. effective din naman.
    Oct 2009
    shampoo lang gamit ko..kundi man joy tanggal pati tilansik ng tubig na may langis langis ng kaunti..
    kaso ngalang after ng ulan dapat buhusan mo na siya ng malinis na tubig para hindi matuyo sa windshied mo ung mga natirang
    recedue ng joy
    I buy my windshield washer fluid from the Casa
    Nabuhay??? Nawala ng ilang days sa tsikot si madam c4y heheheh
    Sent from my GT-I9300 using Tapatalk 4 Beta
    Jul 2011
    1. Wag ka gagamit ng tubig poso sa water reservoir.
    2. Kung OC ka sa water spots, gumamit ng distilled water (ex. Wilkins)
    3. Lagyan mo ng konting JOY ung tubig, pampadulas din un.
    Ung wiper pag hindi na pantay ang hagod, palitan mo na, mas mura ang wiper kesa ma-accident ka.
    Wag iinom ng Beer/Gin/Whiskey para uminit ang katawan kung gusto mo mag-drive pag tag-ulan.
    Jan 2009
    ^ Won't the degreasing chemical of Joy strip the wiper blade off its natural oil in the rubber?
    I just use filtered drinking water. When the car was new, I spent a lot of money on Wilkins.
    I just buy the Toyota OEM washer fluid and use it on our cars. Cost is around P 100 or so if i recall correctly (1L).
    Jul 2011
    Sir anung kulay nito? though wala naman bearing sakin ang color, gusto ko lang malaman,
    may mga shops din ba na nagbebenta sa banawe nito? might try this one.
    or
    any of you guys tried polyglaze windshield washer fluid? eto kasi madalas ko makita sa ace.
    Jan 2003
    I regret buying the ones available at blade for 88. It left a nasty watermark on my newly painted hood. From now on, Ill just use filtered or distilled water.
    Quote Originally Posted by 7138 View Post
    It's clear. The Toyota stores in Banawe (I.e. Toyorama) should have this AFAIK.
    Quote Originally Posted by Manilablock View Post
    Agree bro.
    An ounce of prevention is unquestionably more desirable than a ton of cure.....(ang sarap pa namang uminom kapag umuulan.... kape na lang...
    19.5K:thatsit:
    I use Microtex Wiper Bead. 190 ata for 2 liters. No need to dilute. Effective in both cleaning and coating the glass with a bit of rain repellant. Booster ng Stain Guard.
    Agree with filtered or mineral water plus liquid soap. Practical na wala pang maraming abubut sa garahe.
    4liters pa naman capacity nung isang washer fluid ko, kaya impractical kung gagamit ng fluid worth 100pesos per liter.
    Baka kung yung binibili pa sa carshop ang ilalagay e hindi luminis yung windshield, manghinayang dun sa kapipindot sa washer fluid.hehehe
    Sep 2011
    Also tried tonight the filtered water + joy mix.
    Nawala yung gritiness ng wiper kapag nag sweep siya.
    Also noticed na mas clear yung glass after, though sa una medyo malabo since nag bubula yung soap.
    BTW i noticed na kapag matagal naka on yung washer spray, nag auto off siya?
    Same goes for the rear one. Does it heat up that much ba? Pinalitan ko kasi nung umuulan kanina, so I am left to drain the reservoir via washer spray.
    Feb 2010
    i'm using toyota winshield washer fluid + distilled water, no issues on watermarks and extends the life of my wiper blades
    Quote Originally Posted by chitobarba1972 View Post
    Sir how much cost ng wiper blade vs cost ng distilled water and washer fluid for 4years? Tingin ko sa isang seasin ng tagulan sa atin makakabili ka na ng 2-3 wiper blade bosch or denso brand compared sa cost ng fluid at distilled. Imho lang po. No need to argue, peace.
Windshield Washer Fluids Talk
