Results 1 to 10 of 13
October 18th, 2012 08:59 PM #1
For those toyota vehicle owners with automatic transmission, what ATF brand/specs did you use when you changed your ATF?
I know that the recommended fluid for most AT vehicles is Type-IV, however, do you know of any alternatives? Sa casa lang ba available ang Type-IV na ATF, magkano kaya ito?
Also, how much ATF do I need (liters/quarts) for an 02 Altis?
Thanks!
October 19th, 2012 09:51 AM #2
Im using toyota atf type IV since 2005 pa, never thought of changing it with another.
Its still efficient and smooth.
Baket ka nga ba magpapalit? Nasa 400pesos/li na yata ngayon yung toyota atf.
You can use Royal Purple atf, its type-IV approved.
Nasa 700pesos/liter price nya dati about 1 year ago.
You only need 3 liters for a routine drain and refill atf change.
October 19th, 2012 10:07 AM #3
Thanks for the info sir!
I am just doing a drain and refill, and I was wondering if it's easier and cheaper to source an alternative to T-IV ATF.
Baka lang meron readily available sa mga autosupply.
Looks like I'll just stick with the Toyota Type IV as recommended. Do I just walk-in sa casa service area and ask for it?
Thanks!
October 19th, 2012 02:46 PM #4
Yes sir walk-in ka lang. Just look out for the job order sheet, usually they will charge you with 4 liters atf, which actually you'll only need 3. (-kasalanan ko last time...di ko napansin na 4 liters yung nai-charge na atf sa job sheet, and also yung engine oil...ginawa din nilang 5 liter...which should only be 4liters).
Kaya nga better...kung bumili ka nalang ng 3li sa casa (around 400/li can), then ipagawa mo sa suking talyer or gas station.
October 19th, 2012 02:54 PM #5
You can buy it directly at the CASA parts counter. Better to stick to it indeed.
- Jul 2008
- 935
October 19th, 2012 03:14 PM #6Try Royal Purple Max ATF, its T-IV. This is what I use in my Hi-ace(Subic) and never had a problem since day 1.
October 19th, 2012 06:03 PM #7
October 19th, 2012 06:19 PM #9
Ito sir gerald mas mura. Synthetic na T-IV na din. Castrol Import Multi-Vehicle Automatic Transmission Fluid (ATF)
http://www.castrol.com/liveassets/bp...s_ImportMV.pdf
October 22nd, 2012 08:37 AM #10
siya nga. i tweeted the mmda and they replied it's suspended nga.
Traffic!
