Page 11 of 18 FirstFirst ... 789101112131415 ... LastLast
Results 101 to 110 of 179
    #101
    Quote Originally Posted by RF02 View Post
    may slight movement po sir, kahit handbrake lang or both
    HTH
    meron about 3-5" siguro
    Aug 2012
    #102
    Quote Originally Posted by granro01 View Post
    According to casa mechanics, you can still tow a car or an SUV with AT in neutral but to a maximum distance of 15km. only. Beyond this there is a possibility that you damage your transmission. AT neutral is not fully disengaged not like the manual transmission.
    Nakalagay naman sa user manual ng A/T car yung proper way of flat towing. Maximum 50km yan, not 15km.
    Emergency Towing / Flat Towing
    In case of a roadside emergency with a disabled vehicle (without access to wheel dollies, car hauling trailer, or flatbed transport vehicle) your vehicle (regardless of transmission powertrain configuration) can be flat towed (all wheels on the ground) under the following conditions:
    - Vehicle is facing forward so that it is being towed in a forward direction.
    - Place the transmission in N (Neutral)
    - Maximum speed is not to exceed 50 km/h
    - Maximum distance is 50 km
    - Put the key in "ACC" (engine off) or "ON" (engine running)
    Dec 2013
    #103
    Quote Originally Posted by 012512 View Post
    Tanong ko kapag nagbrake ka sa downhill, tapos naiset mo sa park then release the brake, may movement play pa ba bago mag lock yung wheels or dapat once you set the lever to P ay wala nang movement na mangyayari sa oto regardless of the slopes?
    Merong movement yan pero dapat onting onti lang.
    #104
    tried it again earlier, parang 1" lang, definitely less than 3".
    baka dahil di ganun ka incline? c5 over pass going to libis.
    #105
    Nakita ko po recently sa FB page ng top gear yung nangyari sa isang fortuner, na bumangga sa 7-11,
    2 possible reasons lang po ang nakikita ko.
    1. Newbie Driver
    2. Lack of awareness, (distraction dahil may kausap sa CP [Common]) at nakalimutan ilagay sa "N" or sa "P"
    Since gate-type shift po ang fortuner, (nakapag-drive na rin po ako) kahit hindi fully depressed sa brake pedal, From D, papasok sa N going to P,
    Kaya maging aware at vigilant po tayong lahat all the times... AT man or MT,
    Hopefully, no one is injured from both sides during this kind of accident.
    https://www.facebook.com/topgearphil...type=1&theater
    #106
    meron.
    yung "P" kasi, iikot nang kaunti yung metal gear sa loob ng AT, hanggang "mag-shoot in" sa butas yung pantusok (anubanaman kasi itong tagalog... so cumbersome to use when describing technical details!) para hindi na umikit... with wear and tear, tolerances increase and this movement increases also.. just a few inches..
    in most handbrakes, it is the brakepads that push against the brake disc or brake drum, and no movement is allowed whatsoever..
    btw, the "P" is a safety feature and is not designed to replace the handbrake. it is also easy to destroy that "P"... as in, kapag nabangga (or so it is written)..
    #107
    Yung GS ba yan?
    Yung akin sa N ko lang nilalagay pag naka park sa grahe namin
    Sadly,- it is the GS, bro.... And, I don't like it that way....
    “The measure of a man is what he does with power – LJIOHF!”
    Duterte for President of the Philippines in 2016!
    25.5K:cold:
    Dec 2014
    #108
    noob question again,
    Pag R (reverse) ba, and you release the break it will move already slightly like in D? or sa D lang yun?
    Jul 2013
    #109
    pag nirelease yun brake habang naka R?
    pag flat or pababa OPO aatras kahit walang apak sa accelerator
    pero pag paakyat yun reverse mo tapos nirelease mo yun brake aba'y aabante pa sir hindi aatras! haha
    Jun 2006
    #110
    We used to have a joke when we were in High School:
    P for Power
    R for Race
    N for Nitro
    D for Destroy
what's the use of "N" in a AT?
