Results 1 to 10 of 16
- Dec 2006
- 273
September 8th, 2007 05:01 AM #1Hey Guys! I need your comments / advice.
When I was on my way to work, I happen to pass by EDSA / Estrella. It was raining then and on that area is flooded above-ankle deep. Then, my car began to loose power and it came to a stop. After about 3 mins., I cranked the car and it started, but once I press the accelerator pedal, it stops. I managed to get the car on the side. Waited for 5 mins, then car starts. What I did was put the tranny in the "2", and the car slowly creeped out of the area. What do you guys think what went wrong?
I appreciate your comments & suggestions.
September 8th, 2007 07:00 AM #2
the water might crept in yout a/t.. have it totally fushe, including the ATF in the Torque converter..
next time, wag sugod nang sugod sa baha.. lalo na kung alam mong may nakikita kang tulo sa garahe mo uma-umaga...
- Dec 2006
- 273
September 8th, 2007 07:58 AM #3Alwayz Yummy, I thought kasi, nawalan ng koryente kaya ayaw mag-ignite..so pinasukan pala yung a/t...pwede kayang magpa-flush sa mga petron centers? saka palagay na rin kaya ako ng bagong atf kasi, kahit naka on yung o/d, tagal mag-up shift, sa tingin ko lang, kapag di pa uminit yung langins sa loob, eh di pa sya mag-up shift....
September 8th, 2007 08:21 AM #4
oo pwede sa mga gas stations. dapat na rin palitan a/t trans oil mo, parang tagal na yan di napapalitan ah..baka blessing in disguise diin yan para magawa mo na agad mag flush ng transmission habang wala pang major problems kundi mas lalong malaki gastos mo in the future.
- Dec 2006
- 273
September 8th, 2007 08:50 AM #5BlueBimmer, pwede na siguro yung Petron ATF, or Castrol ATF? Ilang liters kaya kapag nai-flush out na yung lumang atf? pwede rin kayang mag-lagay ng atf additive? And also pala, since city driving lang naman ako, ilang kilometer ang itatakbo para malaman kung dapat ka na magpalit ng atf?
In addition to that, question lang Guys...bakit nag-stall yung engine? inilagay ko sa "N", nag-crank lang sya, at ayaw mag-start. So, hinala ko, baka nawalan ng koryente sa ignition system.
September 8th, 2007 11:47 AM #6
I doubt if ankle deep water can reach your auto tranny. Baka mabilis takbo mo then nag splash yun water sa engine bay mo. Nabasa yun mga sensors kaya di mag start. After a few minutes nag dry na siya because of the heat ng engine. Anung car ba ito?
September 8th, 2007 12:09 PM #7
pag check mo sa ATF mo, refer ka sa ATF-faq thread na naka-pin dito sa workshop..para makita mo condition ng ATF mo... at compare mo sa pics na nandun...
8 liters, and remember-->its not the brand that is first priority when buying ATF: its the spec: DEXRON, DEXRON2/3, MERCON, C4, etc--iit is also stated in the ATF faqs thread na naka pinned dito sa workshop..
- Dec 2006
- 273
September 11th, 2007 08:12 AM #9
ususally nga po 5-6 liters po lahat lahat, 1/2 of the atf is in the oil pan, the other half is on the torque converter(TC)...
search mo a/t threads na nireplyan ko, halos lahat dun nasabi ko na panu palitan ang nasa TC nang di na kailangan ng machine/DIY way...
- Dec 2006
- 273
September 11th, 2007 08:23 AM #10Salamat, bro...
actually 5 - liters lang nilagay ko..pwede na siguro yun...
ok lang kaya kung lagyan ko ng A/T treatment gaya ng X-1R?
Xiaomi E-Car
