Sir, umaandar naman ng ok yung kotse pero hindi ko sure yung sa clutch, medyo iniiwasan ko kasi tapakan kanina eh.
Never ko na feel yung ganun sticky/stuck sa clutch ko since binigay sakin last May.
From Guadalupe to Rockwell bihira ko tinapakan yung clutch. Then sa rockwell I checked under the hood, ok naman yung clutch fluid ko medyo amoy sunog na clutch nga lang.
Thanks
what does "sticky clutch" mean?
are we refering to the clutch disc, na parang dumidikit? baka contaminated with lubricant or... you might have to have the disc cleaned..
or are we refering to the clutch pedal? baka naman kailangan lang ng grasa ang clutch pedal swivel joint... baka na-tuyo na sa kaka-clutch-driving mo..
I think may signs nga ako ng pagkaclutch driver!
Pag nagbrake ako, usually sabay ng clutch down but the purpose is to shift to a lower gear. Pag nasa stop light naman, neutral ako then handbrake. And i dont keep my foot on the clutch. Once I shift gears, let go ko totally clutch and foot rests on the floor.
For as long as the ride is "rolling",- the engine would not turn off.
So, the last opportunity when you can step on the clutch is when you feel the engine "trembling with fear" ....
26.2K _/_/_/_/_/:shower:_/_/_/_/_/
Kapag traffic and seconds lang ang interval eh uusad na yung mga sasakyan, ok lang po ba yung half clutch ang gamit then half brake? puro ganon hanggang sa totally makalampas sa traffic? is it clutch driving?
Ang alam kong clutch driving ay yung nakaapak pa sa clutch (of course not fully depressed and pedal) kahit tondo andar na sasakyan.
Kung traffic at yung stop and go ay segundo lang ang pagitan, aapak din ako sa clutch without shifting to neutral.
How else are you going to move forward in bumper to bumper traffic?
Sakin pag traffic aangat ko lang ng konti yung clutch then gas konti then balik kagad sa full pressed sa clutch tapos coasting na lang then brake...
