Results 11 to 16 of 16
- Feb 2008
- 35
September 12th, 2008 05:28 PM #11PROBLEM Solved! Thanks to all your suggestions. I brought it to Speedy Fix and the personnel there checked it. May pinutol lang sila sa may cable and walla! Its now shifting to "L" low gear. Mababait ang mga tao dun sa Speedy Fix. Nagpa-change ATF na rin ako doon at change oil using Royal Purple. I highly recommend the shop. Sayang at wala dun si speedyfix at hindi ko nameet. Thanks again people. God Bless.
September 13th, 2008 01:22 AM #12
- Feb 2008
- 35
September 13th, 2008 07:57 AM #13
THE AUTO SPECIALIST
- Mar 2006
- 607
September 13th, 2008 09:29 AM #14singit lang mga bossing , pero kung yan lang ang paraan para maayos ang trouble , siguro okey na rin
at least nakatipid ka bro
- Feb 2008
- 35
September 13th, 2008 01:59 PM #15Thanks bro. Tingin ko naman ok yung mga gumagawa sa speedy fix. Pagadating ko dun sinabi ko yung problem tapos they checked the ATF palitin na raw at medyo kulang so after nung change ATF chinek yung stick shift tapos yung ilalim and they informed me dun daw sa cable yung problem kaya ayaw pumasok sa low gear. Pinakiramdaman ko naman after magawa ok naman takbo nya at shifting.
Tsikot Member Rank 5
- Nov 2003
- 3,849
October 19th, 2008 04:28 PM #16hehe! i doubt may pinutol sila. maybe they adjusted the cable lang. i doubt my boys would cut a cable since we would not be able to reattach it again coz the end has a lock
siguro even in L, the cable was too lose kaya it could not engage 1st gear
glad you're happy with the work and that the car is back to normal
***y welds! Apparently the subcon that makes the part replaced a worn welding tip but did not...
Chery returns to PH
