Results 1 to 10 of 16
- Feb 2008
- 35
September 10th, 2008 09:30 PM #1Mga bossing patulong naman newbie lang. Nagpark kasi ako sa basement ng isang building sa Commonwealth near St. Peter's Church yesterday nung palabas na ko sobrang taas ng paahon. At first hindi nakaya ng oto ko ang paahon so i tried to shift it sa low gear (L) pero ayaw pumasok galit na galit ang makina at kumakamot ang gulong. So what i did was umatras pabalik sa basement para kumuha ng bwelo and i activated the overdrive. Finally nakaahon ako. My worry is after this may naamoy ako na parang sunog na goma. Is it the ATF or nagoverheat and tranny ko or gulong lang yun na naginit sa sobrang kamot? Paadvise naman hindi kasi ako mapakali baka nasira ang tranny ko. TIA.
September 11th, 2008 02:01 AM #2
Its just a burn rubber. Dont worry your tranny is very much okey. Anyway, go easy on uphill unless your engine is a brawler.
- Feb 2008
- 35
September 11th, 2008 07:25 AM #3
September 11th, 2008 09:07 AM #4
You can test this by putting your tranny in L and driving around. If your tranny still shifts to a higher gear as you speed up then you might have a problem. If your tranny stays in one gear then no worries.
September 11th, 2008 10:24 AM #5
Were you shifting while you were stepping on the gas very hard? It might be your tranny saving you since if you are revving the engine very high as you spin the tires and shift to a lower gear you are more likely to cause tranny damage. The last thing you should be doing going up a steep incline is using overdrive as that allows the engine to go to the highest gear. Going up steep slippery inclines it is better to be light on the gas to prevent wheel slip.
- Feb 2008
- 35
September 11th, 2008 02:27 PM #6
September 11th, 2008 02:55 PM #7
You can test, if you are in L. Count the number of shifts it makes when you're in L, and compare it to its intended gear (2nd or 1st). So if you have a 4-speed auto, if L is equal to 1st gear, there should be 3 shifts when in D, but if you leave the shifter in L, it should not upshift unless L also includes 2nd gear.
You should be fine, you said your tires squealed, yun ang amoy sunog.
- Feb 2008
- 35
September 11th, 2008 04:49 PM #8
September 12th, 2008 01:39 AM #9
This transmission does use vaccuum to shift? If it is your problem could be in a vaccuum line or the "shift modulator". This could also be because the filter and fluid need changing. If this is the case, take it somewhere and have it flushed it.
If hasn't used vacuum to shift then your transmission one is controlled by a cable and the valve body, it probably just needs a good filter and fluid change done on it right now, its not picking up the fluid fast enough to enter the transmission, and this is causing it to not shift right, have it changed ,and have the bands adjusted while your at it, and it will shift a lot better. Good luck, hope this help.
- Feb 2008
- 35
September 12th, 2008 05:18 AM #10
I think the weight ratio between the vehicle and the driver will have something to do with it....
Wheel Alignment
