Results 1 to 16 of 16
    Mga bossing patulong naman newbie lang. Nagpark kasi ako sa basement ng isang building sa Commonwealth near St. Peter's Church yesterday nung palabas na ko sobrang taas ng paahon. At first hindi nakaya ng oto ko ang paahon so i tried to shift it sa low gear (L) pero ayaw pumasok galit na galit ang makina at kumakamot ang gulong. So what i did was umatras pabalik sa basement para kumuha ng bwelo and i activated the overdrive. Finally nakaahon ako. My worry is after this may naamoy ako na parang sunog na goma. Is it the ATF or nagoverheat and tranny ko or gulong lang yun na naginit sa sobrang kamot? Paadvise naman hindi kasi ako mapakali baka nasira ang tranny ko. TIA.
    May 2007
    Its just a burn rubber. Dont worry your tranny is very much okey. Anyway, go easy on uphill unless your engine is a brawler.
    Quote Originally Posted by v6dreamer View Post
    Thanks v6dreamer. My other concern is that it does not shift to low gear which is "L" right? is there something wrong with my tranny or it is just the stick shift? Thanks again.
    Aug 2004
    You can test this by putting your tranny in L and driving around. If your tranny still shifts to a higher gear as you speed up then you might have a problem. If your tranny stays in one gear then no worries.
    Were you shifting while you were stepping on the gas very hard? It might be your tranny saving you since if you are revving the engine very high as you spin the tires and shift to a lower gear you are more likely to cause tranny damage. The last thing you should be doing going up a steep incline is using overdrive as that allows the engine to go to the highest gear. Going up steep slippery inclines it is better to be light on the gas to prevent wheel slip.
    Quote Originally Posted by redorange View Post
    No i was not shifting while stepping on the gas. I was on a full stop when i tried to shift it to "L" but in vain. Thanks.
    Jul 2006
    You can test, if you are in L. Count the number of shifts it makes when you're in L, and compare it to its intended gear (2nd or 1st). So if you have a 4-speed auto, if L is equal to 1st gear, there should be 3 shifts when in D, but if you leave the shifter in L, it should not upshift unless L also includes 2nd gear.
    You should be fine, you said your tires squealed, yun ang amoy sunog.
    Quote Originally Posted by mbeige View Post
    Thanks man but the trouble is that I can't shift it to "L." only to "D" "P" "N" and "R." Am really puzzled if the problem is with the tranny or just the shifter. Thanks again.
    May 2007
    This transmission does use vaccuum to shift? If it is your problem could be in a vaccuum line or the "shift modulator". This could also be because the filter and fluid need changing. If this is the case, take it somewhere and have it flushed it.
    If hasn't used vacuum to shift then your transmission one is controlled by a cable and the valve body, it probably just needs a good filter and fluid change done on it right now, its not picking up the fluid fast enough to enter the transmission, and this is causing it to not shift right, have it changed ,and have the bands adjusted while your at it, and it will shift a lot better. Good luck, hope this help.
    I really don't know but to make it sure as you suggested, I will just bring the car to a shop and have the tranny checked. Thanks to all your suggestion. God Bless.
    PROBLEM Solved! Thanks to all your suggestions. I brought it to Speedy Fix and the personnel there checked it. May pinutol lang sila sa may cable and walla! Its now shifting to "L" low gear. Mababait ang mga tao dun sa Speedy Fix. Nagpa-change ATF na rin ako doon at change oil using Royal Purple. I highly recommend the shop. Sayang at wala dun si speedyfix at hindi ko nameet. Thanks again people. God Bless.
    May 2007
    Quote Originally Posted by thehitman777 View Post
    What, pinutol? It may sound's not a right term(PINUTOL). Can you specify kung anong ginawa. It may solve that (L) problem, but what if???? Im not trying to scare you, just concern.
    Pinutol ng mga half inch yung dulo ng cable na may thread na naguugnay sa shifter at sa tranny. Delikado ba yun boss?
    singit lang mga bossing , pero kung yan lang ang paraan para maayos ang trouble , siguro okey na rin
    at least nakatipid ka bro
    Quote Originally Posted by bambino View Post
    Thanks bro. Tingin ko naman ok yung mga gumagawa sa speedy fix. Pagadating ko dun sinabi ko yung problem tapos they checked the ATF palitin na raw at medyo kulang so after nung change ATF chinek yung stick shift tapos yung ilalim and they informed me dun daw sa cable yung problem kaya ayaw pumasok sa low gear. Pinakiramdaman ko naman after magawa ok naman takbo nya at shifting.
    Nov 2003
    hehe! i doubt may pinutol sila. maybe they adjusted the cable lang. i doubt my boys would cut a cable since we would not be able to reattach it again coz the end has a lock
    siguro even in L, the cable was too lose kaya it could not engage 1st gear
    glad you're happy with the work and that the car is back to normal
AT Not shifting to low gear
