Results 21 to 40 of 57
    #21
    Quote Originally Posted by ieddam View Post
    Anong model ito? Parang ngayon lang ako nakaencounter ng A/T na kailangang ishift to neutral bago mag start.
    Am also curious as I've never encountered or heard na may ganun requirement to start a car.
    Feb 2019
    #22
    Suzuki Celerio 2020 CVT. I’m not sure kung tama ba pagkakaintindi ko. Haha pero kasi base sa nabasa ko, ganun yung sabi sa owners manual. Not sure kung required ba or not kaya gusto ko din sana iclarify dito. Hehe
    Apr 2014
    #23
    Starting The Engine; Using The Transaxle - Maruti Suzuki CELERIO Owner's Manual & Service Booklet [Page 8]
    Mukang shift to n nga ang nakalagay sa user manual.
    Aug 2017
    #24
    Quote Originally Posted by chronicle View Post
    Kaya pala. Yung nandyan sa owner's manual is an auto gear shift
    Yung sa atin kasi is a regular torque converter CVT.
    Always start the car in P, that's a safeguard in case you forgot to set the parking brake.
    Feb 2019
    #25
    Ah okay, so safe to say na i-start ang engine when in P? Mula kasi nung nakuha ko to, nilalagay ko sa N muna bago ko magstart. Hindi ba masisira yun?
    Feb 2019
    #26
    If okay lang na i-start ang engine sa P, then what’s the use of N? Pag traffic lang, or matagal kang magstop?
    Quote Originally Posted by jnsk View Post
    I usually put it on N sa stop and go traffic that would last at least 60secs.
    Pero sa pag start ng engine, usually sa park this is to guard your car not to move forward or backward kung hindi pantay ang parking and hindi ka naka handbrake...
    Also, wala sa manual na sinabi put it on N then step on the brake and start your engine... goodluck sir!
    #28
    Use P when going to park. Use N on all others. Especially when there is a risk of collision. U don't want to transmission to be stuck in P when u get bumped. Transmission damage yan, sureball.
    Jul 2019
    #29
    Kahit bago? [emoji22]
    Oo nga. 1st time lang naencounter na shift to N muna bago start ignition. Hindi safe yun. Yan din ba ang instruction sa casa bago i hand over ang new car sayo sir? Tanong ko lang kung na try mo na ba i start ang engine ng naka P ang lever..nag start din ba or ayaw gumalaw ang key?
    Jul 2019
    #30
    Worried kasi ako baka delikado if ginagamit. But anyway, pacheck ko nalang siguro sa casa tomorrow. Thanks guys!
    Its cable slack because the parking brake is not engaged. normal lang yan sir na gumagalaw ng kunti ang hand brake lever mo kasi walang tension ang cable. parang naka hinged lang yung hand brake lever mo sa base or holder nya kaya meron talagang free movement yan. anyway, casa technician can correct the problem kung magpaservice ka.
    #31
    Quote Originally Posted by nelyoung View Post
    Wala kasi syang "P". Tinipid talaga. Walang parking lockout yun transmission.
    Feb 2019
    #32
    Thanks sir!
    Feb 2019
    #33
    Actually dun ko lang nabasa sa owners manual, pero for different transmission ata yung nabasa ko. But anyway, malinaw na sakin lahat. [emoji4] Thanks guys!
    Mar 2018
    #34
    It's a default when starting automatic transmissions. No need for the extra effort to engage to N when you are about to start your car unless you still drive a manual tranny.
    Apr 2014
    #35
    So *jnsk.
    Can you confirm na same yung user manual ng india at ph?(amt and cvt respectively)
    If same, that's idiotic of suzuki ph to not update it to include cvt.
    Feb 2019
    #36
    I guess mali lang ako ng pagkaintindi sa nabasa ko. For manual ata ito kasi may isang part din ako nakita na may sinabing for CVT. Sorry guys, this is my firs time to have a car kaya wala pa kong idea sa mga ganito. [emoji4]
    Apr 2014
    #37
    Amt / auto gear shift din ang nasa ph manual?
    Feb 2019
    #38
    Ito ata yung for at/cvt/mt.
    Malaking tulong din talaga na binabasa ang owner’s manual. [emoji4]
    #39
    that's nice!
    the three versions of the stick are mentioned.
    mabuhay ang mambabasa ng owner's manual!
    Mar 2018
    #40
    Quote Originally Posted by istan View Post
    so if you're CVT ride is parked at nabangga ka sa kasamaang palad (causing the vehicle to lurch forward or backward) or na-hatak ng mga beloved MMDA enforcers, sira na tranny mo?
cvt on idling
