Page 1 of 3 123 LastLast
Results 1 to 20 of 57
    Jul 2011
    good day everyone!
    is it a good thing to put my transmission on Neutral ( more or less 2-4 minutes) with the handbrake engaged while stuck in a traffic or waiting for a green light ? my cvt is of honda and subaru
    thanks
    Quote Originally Posted by dropzone View Post
    good day everyone!
    thanks
    i also recommend that, po.
    it's also safer.
    Jul 2011
    it's also safer.
    thanks sir
    whatevers comfortable. slow speeds or low torque applications arent that demanding naman.
    Better for CVTF also pag neutral
    May 2009
    I thought that was common practice now for any auto-tranny, aside from giving your transmission a rest, 2 to 4 minutes on D is not only tiring on your foot, it can also be dangerous because there's a risk you could lose grip on your pedal and the car suddenly lurches forward.
    Quote Originally Posted by sparc179 View Post
    on the new civic.. i use autobrakehold
    May 2009
    Good for you sir, that your car has that feature.
    May 2019
    Turo rin po sakin yan sa Driving School.. pero not advisable po sa uphill / downhill sa pagkakaanda ko.. Kaya dahan dahan din po irelease ang brake kapag naka-Neutral na + Hand Brake.. Para sure na di gagalaw sasakyan.. Grabe naman kasi ang more than 8 minutes na traffic..[emoji24] Iba na din sa pakiramdam mas prone na mabitawan ang brake sa tulad ko na first time driver..
    Sent from my SM-J730G using Tapatalk
    if i knew it would take that long, i would have turned the engine off.
    Feb 2019
    Guys, pasingit lang. Normal ba na parang maluwag yung hand brake pag nakababa? I mean may 1-2cm syang naangat na parang lose? Or kelangan ipacheck?
    Also, before starting engine, oks lang bang magshift from P to N then saka iistart? Vice versa pag papatayin yung engine. Thanks!
    Quote Originally Posted by jnsk View Post
    hand brakes need adjustment from time to time, to take up the slack caused by brake pad wear and cable stretch.
    sometimes, the lever itself is worn from age...
    if your car allows for moving the stick from P to N before starting, then so be it. you just lose the extra protection of the P brake, in case you forgot to put on your handbrake.
    some cars will not normally allow such movement from P to N, until after the engine starts.
    Feb 2019
    Kakakuha ko lang ng oto ko 4 days ago eh. Napansin ko lang kanina parang maluwag sya, pero oks naman pag inaangat. Mahigpit pa. Pag nakababa lang parang nawiwiggle up and down.
    Yes, binasa ko kasi yung manual nya, sabi need to shift from P to N before starting engine. Nashishift naman sya as long as naka ON yung keys.
    Apr 2014
    Slack on the cable probably.
    Feb 2019
    Quote Originally Posted by chronicle View Post
    Kahit bago? [emoji22]
    pa-adjust nyo.
    mura lang yan.
    i am not on banawe's payroll, but...
    if it is not inconvenient to you, drive there and let them boys have a go at it. they do it all the time. they already know the wrench sizes and screwdriver types needed for the job.
    errr... what car na, po?
    kung bago, bring it to the casa.
    they should fix that for free.
    Feb 2019
    kung bago, and you do not want to spend for it, bring it to the casa.
    Worried kasi ako baka delikado if ginagamit. But anyway, pacheck ko nalang siguro sa casa tomorrow. Thanks guys!
    brand new cars should be perfect, upon delivery.
    but we are all human.
    i guess that is what warranty is for.
    my owner's manual says that the brakes should bite with two to three clicks.
    good luck, po.
    Aug 2017
    Anong model ito? Parang ngayon lang ako nakaencounter ng A/T na kailangang ishift to neutral bago mag start.
cvt on idling
