how do you know if its happening?![]()
HG: hindi po kaya baliktad, it shouldn't die kasi sliding nga po e.
*bogart: initially, you will feel na parang ang hina ng arangkada but the engine is roaring. Minsang biglaan ang high-rev (kasi dumudulas) but you're not really moving fast.
yung pong case na matagal ka ng tumatakbo then pag nagfull stop ka, mahirap ipasok sa first gear and pag magrereverse ka naman eh ang ingay ng makina? Can you consider it clutch sliding?
what do you exactly mean by "mahirap ipasok sa 1st gear"?
If it sounds unusual enough to make you concerned, have it checked by your trusted mechanic.
parang cguro ayaw pumasok kahit fully pressed ka na sa clutch ayaw pumasok nung 1st gear.
have the clutch cable members checked then or yung clutch pedal mismo.
Ewan ko yung first gear problem, could be a lot of things. But the noisy whirring sound while going in reverse is supposed to be normal. See http://auto.howstuffworks.com/question522.htm
How do u fix the clutch slipping/sliding? Is it just by some adjustments in the clutch mechanism or replacement na talaga ng something? How much will it cost to fix this problem (range)?
Sama ko na rin, ung "free play" ng clutch pedal, pano ba inaayos un? Normal lang ba na may free play ang clutch pedal or zero talaga dapat. Free play, I mean, ung movement ng clutch pedal na useless naman or hindi talaga nagc-clutch.
Hope to hear from you guys! I'm eager to learn more.
fix it by replacing the clutch disc, pressure plate and release bearing.
hi, sa case ko, medyo matigas ang pag-apak sa clutch.... But pumapasok naman all gear changes...
I haven't tried any remedies yet but several mechanics have several opinions..
A mechanic had my car handbreak up, then had it on 1st gear, released the clutch without stepping on the accelator, tumatakbo ang unit ko, kaya sabi nila clutch disc sliding daw..
sabi nila...it either
1. Bleed lang daw...
2. Clutch finger ang sira
3. Clutch disc or pressure plate sira...
Either way, mukhang lalaki ang gastos ko.. hehehe
Any other ideas why matigas ang clutch ko?
ano ba magiging issues when using a vehicle with a sliding clutch aside of course yung mabagal mag-accelerate?
pwede mo rin sirain the flywheel mo which will necessitate refacing it.
pwede ka rin itirik pag sobrang ubos na.
evident ito pag mainit na ang clutch mo lalo pag umaakyat. mataas ang rpm pero di umaandar or mabagal ang takbo...
I have my own question po. I'm being sold a Toyota Hilux 2002. However, the seller says that the clutch is slipping. He had it checked already suposedly and it needs a replacement transmission valve body. Are what he told me credible, and how much should I prepare kaya for repairs? I asked Toyota about it already. I cannot bring the unit to them given that the transmission has been taken down. That given, they said that it could range from a 10k part replacement to something like a 90k overhaul. Paano kaya?
