Results 11 to 20 of 25
October 28th, 2007 10:01 PM #11
have the clutch cable members checked then or yung clutch pedal mismo.
DIY to death!
- Jan 2003
- 451
October 29th, 2007 11:15 AM #12Ewan ko yung first gear problem, could be a lot of things. But the noisy whirring sound while going in reverse is supposed to be normal. See http://auto.howstuffworks.com/question522.htm
- May 2007
- 13
November 10th, 2007 01:44 AM #13How do u fix the clutch slipping/sliding? Is it just by some adjustments in the clutch mechanism or replacement na talaga ng something? How much will it cost to fix this problem (range)?
Sama ko na rin, ung "free play" ng clutch pedal, pano ba inaayos un? Normal lang ba na may free play ang clutch pedal or zero talaga dapat. Free play, I mean, ung movement ng clutch pedal na useless naman or hindi talaga nagc-clutch.
Hope to hear from you guys! I'm eager to learn more.
Tsikot Member Rank 5
- Nov 2003
- 3,849
November 11th, 2007 03:24 PM #14fix it by replacing the clutch disc, pressure plate and release bearing.
- May 2006
- 424
November 11th, 2007 08:46 PM #15hi, sa case ko, medyo matigas ang pag-apak sa clutch.... But pumapasok naman all gear changes...
I haven't tried any remedies yet but several mechanics have several opinions..
A mechanic had my car handbreak up, then had it on 1st gear, released the clutch without stepping on the accelator, tumatakbo ang unit ko, kaya sabi nila clutch disc sliding daw..
sabi nila...it either
1. Bleed lang daw...
2. Clutch finger ang sira
3. Clutch disc or pressure plate sira...
Either way, mukhang lalaki ang gastos ko.. hehehe
Any other ideas why matigas ang clutch ko?
November 12th, 2007 01:50 PM #16
ano ba magiging issues when using a vehicle with a sliding clutch aside of course yung mabagal mag-accelerate?
- Nov 2003
- 3,849
November 18th, 2007 11:02 AM #17pwede mo rin sirain the flywheel mo which will necessitate refacing it.
pwede ka rin itirik pag sobrang ubos na.
- Nov 2007
- 14
November 19th, 2007 08:59 AM #18evident ito pag mainit na ang clutch mo lalo pag umaakyat. mataas ang rpm pero di umaandar or mabagal ang takbo...
- 1
March 3rd, 2008 12:30 AM #19I have my own question po. I'm being sold a Toyota Hilux 2002. However, the seller says that the clutch is slipping. He had it checked already suposedly and it needs a replacement transmission valve body. Are what he told me credible, and how much should I prepare kaya for repairs? I asked Toyota about it already. I cannot bring the unit to them given that the transmission has been taken down. That given, they said that it could range from a 10k part replacement to something like a 90k overhaul. Paano kaya?
- Nov 2003
- 3,849
considering a Ferrari has an average price range of 20-25M. multiply that with 666 units sold then...
Car Sales Data (2024)
