Results 1 to 20 of 25
    Jun 2006
    HG: hindi po kaya baliktad, it shouldn't die kasi sliding nga po e.
    *bogart: initially, you will feel na parang ang hina ng arangkada but the engine is roaring. Minsang biglaan ang high-rev (kasi dumudulas) but you're not really moving fast.
    Quote Originally Posted by Horsepower View Post
    OT: sori, baliktad nga.....
    parang naka neutral car mo while stepping the gas pedal.
    Nov 2003
    your rpm goes up with the speed following suit.
    Jul 2006
    yung pong case na matagal ka ng tumatakbo then pag nagfull stop ka, mahirap ipasok sa first gear and pag magrereverse ka naman eh ang ingay ng makina? Can you consider it clutch sliding?
    Quote Originally Posted by cmcaro22 View Post
    no, there is probably some worn out clutch system components, like release bearing or pressure-plate.
    As for the "ingay ng makina", baka ibang issue naman yan, not related to clutch/transmission system.
    Jun 2006
    what do you exactly mean by "mahirap ipasok sa 1st gear"?
    If it sounds unusual enough to make you concerned, have it checked by your trusted mechanic.
    Jul 2006
    parang cguro ayaw pumasok kahit fully pressed ka na sa clutch ayaw pumasok nung 1st gear.
    Jan 2003
    Ewan ko yung first gear problem, could be a lot of things. But the noisy whirring sound while going in reverse is supposed to be normal. See http://auto.howstuffworks.com/question522.htm
    May 2007
    How do u fix the clutch slipping/sliding? Is it just by some adjustments in the clutch mechanism or replacement na talaga ng something? How much will it cost to fix this problem (range)?
    Sama ko na rin, ung "free play" ng clutch pedal, pano ba inaayos un? Normal lang ba na may free play ang clutch pedal or zero talaga dapat. Free play, I mean, ung movement ng clutch pedal na useless naman or hindi talaga nagc-clutch.
    Hope to hear from you guys! I'm eager to learn more.
clutch sliding!!!
