Page 8 of 8 FirstFirst ... 45678
Results 71 to 79 of 79
    May 2009
    #71
    di naman kaya baliktad yung clutch disc?
    experienced this kind of error pero buti traktorang pambukid ang ginawa ko kaya mas madali dali ang r & r. never had the same error again.
    Oct 2011
    #72
    2013 Fort may hissing sound parang trap air everytime I press and release the clutch. Pero kapag mabilis na takbo like 2nd gear to 3rd gear, 3rd gear to 4th gear, minimal na yung hissing sound if I press/release the clutch. Ito ba yung release bearing problem?
    Nabasa ko rin dito sa tsikot before na if papalitan, isang buo na palitan including pressure plate, pilot bearing etc. Pero if hindi pa palitin tong mga to and release bearing lang ang may wear, puwede kayang hayaan muna hanggang magkaron na rin ng wear and tear yung ibang parts para mas sulit ang palit?
    Or eat the cost and palitan na rin lahat including pressure plate and pilot bearing kahit release bearing lang talaga ang may problema?
    #73
    magkano release bearing?
    magkano pressure plate assembly?
    magkano labor?
    make your choice.
    may mga kilala ako, when the trans is opened for whatever reason, and the release bearing "isn't new anymore", they replace the release bearing.
    Oct 2018
    #74
    Could someone give me an idea how much will it cost for a change of flywheel and clutch assembly (oem & replacement) for new generation everest ambiente and fortuner (2016 above) manual transmissions? #newbiehere
    Jan 2013
    #75
    Quote Originally Posted by monero View Post
    Usually ang labor cost sa labas is 2500. normal cars average ay 10k to 13k oem na yung assembly. Pero siguro mas mahal yan.
    Ang aga naman bumigay nyan sir?
    Jan 2008
    #76
    Why replace? One advantage of manual trans is their long life compared to automatics.. some manual trans can last a lifetime if properly used
    Usually the pressure plate is replaced and not the flywheel
    Nov 2012
    #77
    2016 model ang bilis nga magpalit niyan. Baka under warranty pa yan 3 years pa lang. Go to casa muna.
    Sent from my LDN-LX2 using Tapatalk
    Jun 2005
    #78
    Quote Originally Posted by rusty_ryan View Post
    Possible clutch driver..clutch components are wear and tear items not covered by warranty
    Sent from my MI MAX 2 using Tapatalk
    Apr 2016
    #79
    Up on this thread!
    Tanong ko lang po how much clutch disc, pressure plate, and release bearing for Toyota Corolla big body Gli 4A-FE engine? And how many oil/axle seals does it have? May leak kasi around sa may tranny area, and feel ko need ibaba yung tranny, so might as well replace all para tipid sa labor. Thanks sa makakasagot :D
Clutch Replacement
