Results 41 to 50 of 72
January 22nd, 2006 09:57 PM #41
Originally Posted by banaweonline
January 25th, 2006 02:26 PM #42
does engine oil always smell like gasoline? i had a check sa ilalim kasi ng auto ko and i found some light brown oil e, pero it didnt smell like gasoline. could it be brake fluid?
January 25th, 2006 02:33 PM #43
btw, wala siyang smell e. wala rin naman akong sipon kaya i'm sure na di barado ilong ko. i smelled it twice pa. naka dalawang balik na kasi ako sa trusted mechanic namin and he assured me na wala ng oil leak yung auto ko.
- Nov 2005
- 8
August 14th, 2006 11:59 AM #44Mga sir,
I just need some additional info re clutch problem. i've noticed such symtoms as quoted above w/ my car (corolla xl, M/T), however, the hardshifting only occurs when the engine is hot, say 2 hour travel especially in traffic where you need to use your clutch all the time.
any input mga sir would be greatly appreciated especially like me na walang alam kundi gumamit lang ng sasakyan. hehehe.
August 14th, 2006 12:08 PM #45
August 17th, 2006 12:31 PM #46
MISFIT, same problem as mine. Pero, duda ko sa master and secondary ung sa akin kse bigla nawawala ung clutch pedal ung pressure, kaya nde ko na ma shift. I had my mechanic adjusted the pedal and double check again the master and secondary, nung umulit. Ika 3rd day ko na. So far nde pa umu-ulit, happened to me twice.
- Dec 2005
- 71
August 17th, 2006 09:32 PM #47
Tsikot Member Rank 5
- Nov 2003
- 3,849
August 18th, 2006 07:07 AM #48if may nagbabasa then may tulo. simple. i doubt it's brake fluid tho... malamang sumemplang na yung auto if malakas tulo ng brake fluid. check it tho. super easy to see the bf level naman.
September 5th, 2006 02:54 AM #49
any ideas kung how much papalit ng clutch, i mean the whole package, as in palit lahat?
kinda new on this stuff kasi eh..
September 5th, 2006 09:19 AM #50
8K plus for me. All in na un.
Labor 1,500
FCC pressure plate 2,900
FCC clutch disk 2,300
release bearing 940
2 oil seals 1,000
Good thing you don't have an oil pressure gauge. It'll make you think twice about going 50.
Thick (20W-50) vs Thin (5W-20) Engine Oil Tested
