Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 72
    Jun 2004
    #21
    up ko lang po yung thread.
    #22
    Quote Originally Posted by attic_dude
    i tried number 1 kanina lang when i got home from work. i tried 2 methods. one was quickly releasing the clutch without stepping on the gas, and the other was to slowly release the clutch without stepping on the gas also. for the first method, the car gave an abrupt jerk and the engine died. but the for second method, the car proceeded to move and the engine did not die, the vibration was normal (slight lang), it was as if i did the correct mix of clutch and gas to make the car move. i tried this 3 times with the same result. is my clutch disc worn out na?
    as for number 2 ganun din yung na experience ko.
    any thoughts?
    you can actually make your car move forward by slowly releasing the clutch without stepping on the gas. I do this even on inclines like being stuck in traffic on a bridge. But then I have a 6 cylinder diesel engine ;)
    as for your clutch, it's still looks good to me. ma feel mo naman coz during high revs your engine does not give you the usual speed that it does before. of course the clutch system is one of culprit of this, the other being the ignition or the fuel delivery, heck even a bad bearing in the aircon compressor/ power steering pump/alternator could cause also this symtoms.
    Jun 2004
    #23
    hmmm, mahirap pala i-diagnose yan. i really think na may prob yung clutch ko e. kasi when i'm moving hirap siya ipasok sa 1st and 2nd gear. parang may grinding noise siya before ma completely engage sa 2nd gear. pero nawawala din.
    Aug 2005
    #24
    you mean grinding? yong parang hindi kinagat yung clutch ang gear at mapansin din to kpag hindi mo na full press yung pedal? di kaya clutch talaga prob nyan? try shiftling without shifting the clutch pedal yung ba ang sound?
    Jun 2004
    #25
    Quote Originally Posted by finchy18
    yes that's what i mean. exactly like that. ano kaya prob dun?
    Jan 2004
    #26
    sir. my bet is clutch. kasi grinding gears yung naririnig mo.
    May 2004
    #27
    baka naman kulang lang sa adjustment yang mga pedals mo. pa check mo muna kung tama pedal freeplay baka nakatukod o kung hindi naman, kulang sa stroke to fully release the clutch.
    May 2005
    #28
    sir pasingit na lang po ..
    paano po kung nasa 3rd or 4 th gear ay hindi smooth ang takbo
    (parang kadyot kadyot lang)..
    pero sa 1st and 2nd wala naman po ..clutch din po ba ang culprit doon ?
    #29
    probably not, could be your fuel delivery system.
    #30
    or high tension wires
    Sep 2005
    #31
    Quote Originally Posted by butchokuy
    momoyster,
    last year lang ako palit, actually dec yun. nde nman nababawasan yung clutch fluid although medyo madumi na sya. la nmang sliding.. i usually experiencing this pag or during stop and go. usually me hardshifting sa 1st and 2nd gear. bagong palit ang gear oil ko din, kahapon lang kasabay ng change oil ko.
    many tnx..
    kung bago ang clutch linining mo sir, try mo palitan ng clutch fluid. also check the master for leaks too.
    if all's well, most probably the synchronizer na ang culprit.
    iyung sa gear oil naman, lagay mo lang 90 grade. 140 malapot na kasi
    Aug 2005
    #32
    sabi na nga bah eh.. yung nga ang narinig mo.. kasi sakin I seldom experience that noise only when I change gear without pressing the clutch pedal.. parang ginawa ko automatic.. minsa ang sakit nga sa dibdib kpag narinig ko yan... pero i didnt really mean it na gawin.. fast shift kasi kaya ganun..
    anyways, about the prob.. uhmm.. di kaya kulang adjustement yung clutch pedal mo (distance from the floor) what if? kasi hindi kumagat eh.. or sakto ba yong pag change ng gear full press ba talaga yung pedal? wla bang leak yung clutch fluid? check it muna bro.
    May 2005
    #33
    Quote Originally Posted by afrasay
    Quote Originally Posted by SunTzu
    kya lang pag sa 1st gear or 2nd gear ay wala
    or better i will try to observe my clutch first if its sliding na or what ..
    #34
    opps baka sa tranny n yan...iba ang gears from 1st to 5th.
    May 2005
    #35
    oo nga ,pa check up ko na rin para sure //mahirap pag tumirik pa sa daan ..saan po ba pwede nyo advice na maganda na shop pero di naman taga..around Quezon City lang po
    #36
    speedyfix try to give him a shout.
    May 2005
    #37
    ^^^thanks ,sir Afrasay...
    Jun 2004
    #38
    hmmm, interesting, i did notice some leaking sa ilalim ng engine ko. pero at first glance ang isip ko agad is engine oil. pero it could be clutch fluid. is there a way to differentiate the two?
    Sep 2005
    #39
    suggest ko lagay ka ng newspaper sa ilalim ng car. leave it overnight. then:
    kapag black, diesel oil
    light to dark brown, gasoline engine oil, and smells a bit like gasoline
    kapag reddish, atf
    kapag light to dark brown, smells like ****, gear oil
    kapag almost clear to brown, brake fluid
    kapag clear tapos medyo natutuyo, tubig na iyan. hehehe
    Nov 2003
    #40
    brake fluid is much more wattery that any oil
clutch problem
