Page 4 of 4 FirstFirst 1234
Results 61 to 72 of 72
    Jun 2004
    #61
    is it possible that the culprit of hard shifting of 1st and 2nd gear is the gear oil used? mine got that problem as soon as i changed the gear oil baka mali ang viscosity eh. any comments?
    Feb 2007
    #62
    yung clutch ko may squeeking sound pag inaapakan, should the master be replaced? at least that's what the mechanic told me. I also experienced that kind of problem, I don't get the right acceleration given a high RPM. San ba sulit magpa check ng clutch? any ideas?
    Jun 2004
    #63
    Quote Originally Posted by w3stic3 View Post
    bro experience the same problem with my revo. changed the clutch master and secondary kasi ngka leak before pero ganon padin. maybe its in the springs of the clutch lang.
    Nov 2003
    #64
    aLVin, what car and what gear oil did you put?
    Jul 2006
    #65
    my sister told me they feel sliding clutch when they are in cruise mode, bumabagal daw sila kahit stable yung tapak nila sa gas tapos parang nalulunod daw
    Jun 2004
    #66
    Quote Originally Posted by speedyfix View Post
    sir speedyfix i think its some cheap unknown brand gear oil lang yun eh. and medyo mataas ata yung viscosity as compared to the viscosity reco ng manual. i just went to the talyer to have it changed during my 40k tuneup sila na bumili ng oil eh. do you think its the culprit? will it cause more damage to my gear assembly in the long run?
    Nov 2003
    #67
    depends, if you drive a honda you should use engine oil for the transmission. most other cars will do well with a 75/90 grade gear oil.
    Jul 2004
    #68
    hi,
    let me share my experience on this clutch problem.
    last friday while driving home, nawalan ako ng clutch as in lubog talaga yung clutch pedal. i ended up pinahatak ko na lang yung car.
    nung tiningnan nung mekaniko wala namang leak ng fluid and hindi nga naubos yung fluid nya eh.
    what do you think causes this and what are the parts that i need to change.
    tia
    #69
    nangyari yan sa akin a few months ago...
    bumigay lang yung clutch spring / rubber... costed me 700 (labor + parts)
    Nov 2003
    #70
    your mechanic should be able to diagnose the problem for you.
    Jul 2006
    #71
    nireplace na ng mga mechaniko ng bayaw ko yung clutch set ko.
    nagpaqoute ako ke sir speedy kaso ndi na ata ako makakapunta ulet, cguro yung t-belt na lang sched ko.
    lumabas sa findings micro leak yung sa clutch matagal na daw ganoon kaya ngayon lang lumabas kasi napuno na ng grasa at langis. pero yung disk at pressure plate buo pa maayos na maayos pa, kaso yun nga pinalitan na rin lahat since naibaba na nila
    Aug 2006
    #72
    mga panero,
    Posible bang magkabara yung clutch fluid line? Parang ito problem ko kanina e. Na-stuck in reverse yung kambyo ko - dalawang kamay na gamit ko ayaw pa rin kumasa. Pati yung pedal parang lumalim. (Kaya tarantang-ita akong naghanap ng clutch problems dito sa tsikot ).
    Binalikan ko kanina - puno pa naman yung fluid reserve. Di ko sure kung dahil sa pagbukas ko ng reserve naayos, pero nung inapakan ko uli yung pedal umayos na naman. Umikot pa ako ng parking lot namin, okay na siya. Kaya dasal ko mamaya e makauwi sa amin nang maayos
clutch problem
